10 minutes of performance --HELP?!?!
Old May 6, 2003 | 05:34 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Im having a major problem with my camaro. I just started working on my IROC again (87 IROC, 5.7 TPI) and I am having this issue where the car will perform beautifully for about ten minutes (almost exactly 10 minutes) and after that it almost seems as though something just completely cuts fuel. From that point on, I cannot rev past 3000 rpm, and can only drive on less that 1/4 throttle. Any attempt to give it full throttle leaves the car sucking in gargantuan amounts of air, but not compensating with fuel, basically the car just sputters !! My air/fuel mixture pod suggests that its getting no fuel basically. Upon shutting her down and starting her back up a few minutes later, it runs properly again for a bit.
I've replaced the following items
Ignition control module
Fuel Relay
Maf Relay
My friends are inclined to believe that it is my MAF sensor. I am not one to say they are wrong, but thats one of those "expensive" parts I don't want to have to buy if its not broken so I would like to rule out all possibilities. Any help would be greatly appreciated.
Old May 6, 2003 | 07:17 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Have you replaced the fuel filter lately?
Old May 6, 2003 | 08:24 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
well if it is the maf sensor than just simply unplug it when you have the problem and if it is the maf sensor the second you unplug it the car will run better. .try that and let us know
Old May 6, 2003 | 10:54 PM
BadSS's Avatar
Yep, that was my first thought as well. If you have,,, is there any chance something could have gotten in the tank? Did you leave the cap off for any extended time, use an old rusted gas can to add gas,,, anything like that? Suction from the pump could be pulling crap against the sock filter on the pick-up tube cutting fuel flow. You cut the car off,,, the trash floats or falls off the sock,,, then it takes a while for it to be pulled back to it.
Do you see variances in your fuel pressure when this happens?
Old May 7, 2003 | 02:43 AM
Car: 1987 IROC Z
Actually I replaced the filter just before I started having this problem, no more than a month or 2 ago.,
Old May 7, 2003 | 03:11 AM
Morley's Avatar
O2 sensor. That 10 minutes of running good is more than likely when you first start it and are running in open loop mode. After 10 minutes you hit closed loop and loose it all....Yep, I'd start with the O2 sensor.
Old May 7, 2003 | 03:24 AM
Morley's Avatar
Now for a little rant.
why is it whenever someone has a driveability problem in a MAF car people want to immediatly say; "the MAF is bad"? Do they figure that since it costs $500 it must be the problem? When you have the same thing on a S/D car they don't automatically say; "the MAP sensor must be bad".
I have been running the same MAF sensor for 18+ years on my '85 IROC and it still works fine. If you don't fool with it then it has no greater chance of going bad than any other electronic part on the engine, less in some cases.
Old May 7, 2003 | 06:39 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
That is almost too much of a coincidence. May want to double check that it wasn't installed backwards (arrow points toward engine) and even just replace it again in case it is actually bad.
RBob.
Old May 7, 2003 | 08:17 PM
Car: 1987 IROC Z
I would lean towards the fuel filter if the problem was persistent. Unfortunately howeve,r the problem is intermittent.... any other ideas ?
Old May 7, 2003 | 08:45 PM
AaronIROCZ's Avatar
I am not trying to be cocky but how do you know the maf is good??? Did you unplug it and check to see if it runs any better??? It is one of the most simplest things to do and then you would know for sure it is good. I had a similar problem with my iroc, it would run fairly good when cold but when it warmed up it would pop, spit and sputter and have no power. I took it to the dealership I worked at and it took them a day and a half to diagnose a bad maf. I have never touched it either before this and one day it was bad. Just try to unplug it while running to rule it out if you haven't already.
Old May 8, 2003 | 01:23 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
I have a similar self inflicted problem. Mine was/is caused by the long duration cam I have in the little 305... when it's cold, she runs great, but once it warms up it's a sputter fest... I was just wondering... do you have a custom chip? Any mods that would have effected the A/F ratio, hence is freaking out the 'puter?
Old May 8, 2003 | 10:51 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Sounds like it goes off when it hits closed loo. Could be a bad O2 sensor os something similar. Would not assume MAF since it runs OK open loop, which still uses the MAF, just no O2 corrections. Could happen that the O2 is pegging high or something and making it go hella lean on BLMs and toally bogging. Or the other way. Which would hit exactly......when it went closed loop.
Old May 9, 2003 | 07:59 PM
Car: 1987 IROC Z
Actually, I just put an SLP CAI intake on it .. could the increase in air intake cause the problem ?
Old May 9, 2003 | 08:09 PM
Ed Maher's Avatar
Car: 04 GTO
No, but not connecting something back up when you were done might have, and even that is still doubtful give your symptoms.
Old May 10, 2003 | 04:01 AM
Car: 1987 IROC Z
Im sure that reconnected everything properly...
Old May 12, 2003 | 10:24 PM
Car: 1987 IROC Z
I will be installing a new MAF this week so if that doesnt alleviate the problem, next will be the o2 sensor. ( I know the MAF is like a 3 minute job, I just have to wait for it to get here)
Old May 13, 2003 | 02:04 AM
Morley's Avatar
Isn't that kind of backwards? Start with the cheap component (O2 sensor0 and then the expensive one (MAF).
Old May 13, 2003 | 06:37 PM
Car: 1987 IROC Z
got an almost new MAF for 50 bucks, worst case scenario, its a part to hold on to because I am sure I will need it eventually.
Old May 14, 2003 | 01:41 AM
Morley's Avatar
naaa, 18 years on the same MAF.
Old May 15, 2003 | 08:13 PM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
Anyone ever thought that the cats might be plugged?
Throw a vacuum gauge on the thing. Watch vac at idle. If your cats are plugged, your idle vac will drop as the car warms up. Another way to tell is to feel the exhaust when it starts acting up. Sitting in the driveway at idle, my exhaust was hot enough to fry bacon... from about 20 feet away...
Old Sep 16, 2003 | 04:49 PM
Car: 1987 IROC Z
Well, gotta breathe some new life into this thread.... still need some help folks. Since this original thread, i've taken my car to the mechanic and he has come to the conclusion that the problem is either my computer or prom. I have a 1987 IROC Z28 L98 5.7L 350 TPI, can someone tell me if this ECM would work for it despite what the auction says.
http://cgi.ebay.com/ebaymotors/ws/e...item=2432839235
Additionally, can someone recommend a place where I can get a prom replacement for this one cheap?
So far, all of the jacked up connectors have been replaced and most other options have been ruled out.
Old Sep 16, 2003 | 05:32 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I don't know about the prices there in Texas, but my dealership here has them for about $80.00 and they have the latest updates on them. Also, NAPA carries the ECM's. Don't know what their prices are though. I do know that if you get a new ecm from the dealer, they will charge a core charge if your ecm is not OEM from the factory.
The Trickster!!!!!!!!!!!!!!!!!!
Old Sep 16, 2003 | 06:31 PM
RP1987GTA's Avatar
STOP! before you replace that MAF replace the maf relays...........i've worked on 100's of gm MAF systems.....very rarely are the MAF sensors actually bad......but the relays are almost always the cause of a mAF related problem,even have had brandnew outta the gm box bad MAF relays.Plus guess what GM tells all its techs....REPLACE THE RELAYS BEFORE CHANGING THE MAF!!!!!
Old Sep 16, 2003 | 08:43 PM
Car: 1987 IROC Z
Are those the 3 relays on the firewall next to the Master brake cylinder ?
Old Sep 16, 2003 | 08:55 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes, the first one is the fuel pump relay, & the next two are the maf burn-off relay and the maf relay.
Bubbajones_ya
Jul 6, 2024 08:32 PM
UltRoadWarrior9
Apr 28, 2020 10:39 PM
gta892000
Aug 11, 2019 11:16 AM
WhteRbt
Sep 21, 2015 09:48 AM
Ranbo108
Sep 9, 2015 12:20 PM
