throttle body gasket. which one????
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i recently bought a felpro tpi upper gasket set and the throttle body gasket that came with it is different from the one the car has on there now. the one the car has is open around the iac passage to behind the throttle blades (causing a vacuum leak sorta?)
. the one included with the kit has a sealed triangle shaped opening. maybe my car has the wrong one and has been causing my idle/iac system to act funny. freaking nearly 2000 rpm flare up upon start.
my iac(new) and throttle body have been fully cleaned and lubed.
the setup in question is my 88' 350 tpi. here's a pic of the gaskets.
my iac(new) and throttle body have been fully cleaned and lubed.the setup in question is my 88' 350 tpi. here's a pic of the gaskets.
Car: 1988 IROC-Z
yeah i went ahead and used the one on the right. what the hell is the other used for? earlier models?
or was the gasket re-designed????
or was the gasket re-designed???? Trending Topics
Car: 1988 IROC-Z
yes it does/used to. well now it flares up to about 1500 sits there about two secs and then begins to slowly come back to normal.
it does this more often when the car is hot and has sit only a short while. ie 10-20 mins. it doesn't do it cold.
then at other times it just goes to about 1200 and goes back down normally?
it does this more often when the car is hot and has sit only a short while. ie 10-20 mins. it doesn't do it cold.then at other times it just goes to about 1200 and goes back down normally?
Terrell351
Jun 13, 2021 01:13 PM
mdtoren
Aug 16, 2015 05:45 PM
