How did you gut your airbox???
Old May 24, 2003 | 07:58 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I was wondering, how did you guys gut your airbox? Did you take that plastic piece out and then cut the holes, or did you cut them out with it still attached to the car? Does it make any difference? I'm about to do it because I'm bored, and I'm just afraid of cutting something underneath it that I won't realize is there... thanks.
Old May 24, 2003 | 08:02 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I would pull the air box out. Really just because you would have more room. I don't think you will cut any wires under there. It depends I guess on what you plan to cut it with. If your going to do it cut it all out.
Old May 25, 2003 | 12:18 AM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
for the amount of work that it takes to get that thing out, i would def pull it out and then cut it. i just used a handheld jigsaw and went at it. Took 5 mins of my time and didn't even break a sweat. If you do try it with it still in the car there are no wires to cut besides your foglight wires (maybe depending on how you go about it), but it'll be more of a pain in the ****
Old May 25, 2003 | 04:52 PM
Hg's Avatar
Hg
Car: '87 Z
Ok, I started to take out that plastic piece but on each end there is a clip. Can you remove the clip without destroying it? It looks like it'd be held on just fine with the front screws, but I'd still like to keep these clips. I really don't wanna have to order a couple of clips. It's just a hassle, lol.
Old May 25, 2003 | 09:21 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
You should be able to get the plastic screws out, just pull the middle out and then you can take the whole thing out.......but when you cut the plastic you'll want to use a dremal tool with a cut off wheel...makes the job so much easier. Heres a pic of what I gutted when I was doing the ram air ducting....the thing you see at the bottom is the fog light duct.
Old May 26, 2003 | 09:37 PM
Hg's Avatar
Hg
Car: '87 Z
Well I did it. I just had at the clips with flat head screw drivers and pliers and got them off. I took the plastic thing out, cut out that crap, and put her back in. I think it was a quite noticeable difference. I highly recomend it if you don't have to worry about water or anything. I never drive my car in the rain, so I don't worry about it and wouldn't know if it sucks up water or not.
I think it was a world of difference just gutting the intake, I can only imagine if I did the ram air mod too... it would have been crazy pull afterwards.
Old May 26, 2003 | 10:05 PM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
congrats
Old May 27, 2003 | 02:37 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Wishmaster - I have the same ram-air setup as you! How hot does your car run with the boxes in place?
Old May 27, 2003 | 11:06 PM
the only time I drove the car is when it was cold out, its on jack stands now....but I did notice that the temp went up slightly..
what about your?
Hey? you get more outta the boxes? in your times?
Linson
Oct 24, 2025 02:00 PM
Jeremys87
Jul 14, 2022 09:08 PM
TRAXION
Aftermarket Product Review
Oct 24, 2000 05:23 PM
