Help with chip.. please
Old Jun 3, 2003 | 08:10 AM
87TAinVA's Avatar
I am swapping my 305 TPI with a 350 TPI, I understand that I need to change knock sensor, injectors and the chip. Getting the 350 chip is what I have problem with. Seem like I need to have one burns specificly for this 350 engine. According to the engine code TPA, it is a 1992 350 motor used in a truck. Can anyone tell me where to go about for the chip???
Old Jun 3, 2003 | 11:23 AM
tpi_roc's Avatar
www.gmpartsdirect.com is about the best site for buying memcals, there is an article with part numbers for years end engine sizes that I'll look for and get back to you on
Old Jun 3, 2003 | 11:42 AM
87TAinVA's Avatar
Thx.. tpi_roc
Old Jun 3, 2003 | 12:00 PM
tpi_roc's Avatar
Do you currently or will you have the ability to burn your own proms? Or are you just looking for a one time installable sollution?
Old Jun 3, 2003 | 12:03 PM
87TAinVA's Avatar
tpi_roc
I have no knowledge of burning chip, plus this will be a one time deal for me.
Old Jun 3, 2003 | 12:16 PM
tpi_roc's Avatar
ok still searching
doesn't appear to be where i thought
One thing you can do is call a GM dealer and give them a car year (87?) that matches your combo of engine size, transmission, and gearing, then just get the part number and order off gmpartsdirect.com
Old Jun 3, 2003 | 12:30 PM
87TAinVA's Avatar
I did contact both Chevrolet and Pontiac dealers.. no one can help with anything. They suggested to get an after market chip. I did talk to Summit to no prevail.
Old Jun 3, 2003 | 12:36 PM
tpi_roc's Avatar
Aftermarket isn't the sollution, although I know your dealership pains
Old Jun 3, 2003 | 12:46 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Ed Wright - Fast Chips.
He is always on these boards, try and find him and send him a pm to see if he can get you one; he might be able to tell you what other chips will work.
Old Jun 3, 2003 | 12:48 PM
tpi_roc's Avatar
He might have the information, but I dont recommend buying an aftermarket one just to get your car going, a stock one is in teh range of $40-$60 from gmpartsdirect.com, where as an aftermarket can be as much as $400 for marginal if any gains (without the car being WITH the tuner)
I'm not finding the article i once had, guess you'll have to do the leg work but its easy, i've done it for 2 swaps, just find a car that matches your specs and get the PN, you might really have to drill dealership guys but they deffinatly hve the informatino availiable.
Old Jun 3, 2003 | 02:49 PM
87TAinVA's Avatar
I contacted GMPartDirect.com, and the answer was "16151348 e-prom is for a 350 (L98) TPI engine 90-92" for $41. Is this what I am looking for????. BTW.. thx for all you guys help
Old Jun 3, 2003 | 02:51 PM
tpi_roc's Avatar
Well your'e getting closer but it wont help if its from a 90-92, thats a SD setup and an entirely different ECM
The years you can play with is 86-89 however due to small changes such as VATS (Vehicle anti-theft) and other things, its the best bet to get one SPECIFICALLY for an 87
Old Jun 3, 2003 | 03:10 PM
87TAinVA's Avatar
tpi_roc
Reading from this web site, I thought the chip I need is specific for the year of the engine. What you are tellling me is to get a 87 chip to use with 92 engine???. Please explaine
Old Jun 3, 2003 | 03:11 PM
tpi_roc's Avatar
Ok maybe we should back up, answer the following questions
1.) What year is the car?
2.) what year and model is the ECM (Engine control module)?
3.) what year and ecm is the wiring harness for?
I assumed the car was an 87 due to your nick name
Old Jun 3, 2003 | 03:17 PM
87TAinVA's Avatar
Answer:
1) 87
2) and 3) How do I find out??
Old Jun 3, 2003 | 03:20 PM
tpi_roc's Avatar
Well is the computer and wiring harness original to the car?
If so, then it doesnt' matter what YEAR the engine block is, metal is only metal, what you need to match is sensors, displacement, tranny, and rear-end ratio to the prom, thats all (and of course the right prom for the right ECM)
There are 3 TPI ecms's
1985: '870
86-89: '165
90-92: '730
IF your car is an 87, the ECM is from your car originally (87) and the harness is from the car originally (87) then you have a '165 ecm and need a memcal from a 86-89, to make sure it matches as close as possible, getting a memcal from an 87 is the wisest
now in 87, with a 350, your only stock choice is an AUTO bin, so if you have a manual you're in a tough spot, if you have an auto you're in luck, now you just have to match to the closest rear-end ratio and you're all done, then buy the memcal for that car.
Old Jun 4, 2003 | 07:02 AM
87TAinVA's Avatar
tpi_roc
Thank you so much for your help thus far. I bought the car used so I have to assume that everything is original. The car is indeed Auto with 2.73 rear ratio (per RPO). What is memcal, anyway???
Now, what question can I ask to clearly state what part I need??
Old Jun 4, 2003 | 09:17 AM
tpi_roc's Avatar
memcal is the name of what you're trying to buy, you can't JUST buy a "chip" or a "prom" form GM
Old Jun 4, 2003 | 10:47 AM
Morley's Avatar
Memcal or Calpack. Don't use any of the 89's, they came with VATS (vehicle anti-theft system). Just tell the dealers you need a memcal/calpack for an 87 or 88 GTA Trans-AM with a 350.
Old Jun 4, 2003 | 10:48 AM
tpi_roc's Avatar
VATS sparatically showed up before 89 as well, just something to be aware of.
Calpack isn't used by GM, i believe that was an aftermarket phrase that showed up by jet or hypertech or someone.
Old Jun 4, 2003 | 11:38 AM
87TAinVA's Avatar
tpi_roc
OK, so I will request a memcal for 87 TA with 350, auto and rear ratio 2.73? Do I still need a chip??
Old Jun 4, 2003 | 11:42 AM
tpi_roc's Avatar
This is a memcal
Old Jun 4, 2003 | 11:44 AM
tpi_roc's Avatar
THis is a memcal without the blue cover
The left half of the memcal is the "prom" or "Chip" its what stores the vehicle specific information, you can't just buy it because its soldered to the memcal, you buy the entire MEMCAL from GM.
When you burn custom proms, you solder a ZIF socket in place of the PROM, and then you can take the prom in and out of the memcal, but you still have to start with a memcal as close to your vehicle as possible, as the RIGHT side of it, holds some generic infromation such as number of cylinders, knock filter, yadda yadda.
mitchberry
Feb 19, 2013 10:45 AM
quickkris2006
Theoretical and Street Racing
51
Jan 28, 2011 01:54 AM
chevy014life
Aug 24, 2010 07:01 AM
Nater36
17
Apr 9, 2010 05:28 PM
Gr89RS
May 10, 2007 03:04 PM
