Vats simulator wiring question.
Old Aug 3, 2003 | 04:25 PM
Powerlover's Avatar
I am installing a used TPI system with a painless wiring harness into my 350 powered 1988 mazda rx7. The TPI was from a 90 Vette origionallly, and was swapped into a Jeep and run for a few years. I just recently bought it and polished it up.
Everything has gone smoothly so far, except for the wiring of the little black vats box. There are three wires on it. I know that one is supposed to attach to the purple wire on the harness, but which one? And what do the other two go to? I hate to just hook them up to power and ground and fry something. I had to get the wiring instructions from the Painless website, and have read the whole website several times now. I used the search function, but found nothing on the forum.
I will attach a pic of the module in question.
Thanks in advance for your help.
http://www.home.earthlink.net/~jnrwacker/
Old Aug 3, 2003 | 04:26 PM
Powerlover's Avatar
sorry here is the pic!!!
Old Aug 3, 2003 | 09:43 PM
Powerlover's Avatar
Also, does the fuel pump relay turn the fuel pump on and off as needed, or does it just leave it running? I already have the pump wired from my previous setup, and it would be nice if i didnt have to change it.
Old Aug 3, 2003 | 11:55 PM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
I just put a '92 computer onto my 350 TPI in my '87 Monte Carlo SS. I didn't even need that vats module and also since I don't have the ignition hardware and matching coded key, I had a friend burn me a new chip with VATS disabled...
Old Aug 4, 2003 | 04:40 AM
Powerlover's Avatar
I wish i had a friend that could "just burn me a chip". But that is not a feesable option for me.
Unless there is someone here from the Memphis area that does PROM burning.
Old Aug 5, 2003 | 06:08 PM
Powerlover's Avatar
I spoke with Painless Performance, and the RED wire goes to a 5v source (pulled from the TPS), the BLACK wire is ground, and the GREY wire goes to the vats wire ion the harness.
Thanks for the replies.......
Old Aug 6, 2003 | 04:13 PM
Mark W. Winning's Avatar
I was just checking out your site. You have to put more pictures of your swap up. I would love to see it...
Old Aug 6, 2003 | 05:00 PM
Powerlover's Avatar
I dont know if i would call it a "site" but i will try to add some this evening after dinner.
Street Lethal
Apr 30, 2019 12:14 PM
stalkier
Dec 6, 2015 11:25 PM
djmarch
Aug 19, 2015 12:07 PM
stalkier
Aug 13, 2015 12:59 PM
djmarch
Aug 9, 2015 05:27 PM
