NEED HELP...NO inector pulse
Old Aug 6, 2003 | 07:38 PM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
so earlier today my injector fuse blew...replaced it with the same size fuse...it ran until i shut it off then when i went to start it back up..no injector pulse once again but the fuse is fine....ANY help is much appreciated....with no car i can't work and i need the money...thanks
-mark
Old Aug 6, 2003 | 07:48 PM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
going to try another ecm and to check the resistance on the injectors....
Old Aug 7, 2003 | 12:03 AM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
resistance on 7 of the injectors were 1.5 ohms and on cylinder 8's injector.....it was 4.5ohms...so the controller is pushing alot harder to get a signal to the 8th injector.....now i need to make sure each has 12 volts....gee....thanks for the help everyone...? does anyone know where the injectors all become one in the harness?
Old Aug 7, 2003 | 11:17 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
What you are actually measuring with your ohm meter is the inductive reactance of the solenoid inside the injectors. You should measure 12 volts on both sides of the injectors with key on. The ECM pulls one side to ground to induce current flow through the solenoid. Try unplugging #8 and try cranking. Should crank, but run sh**ty on 7 cylinders. If so, get a new injector. If not, get a new injector and another ECM.
Old Aug 8, 2003 | 08:13 AM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
i measured them with the injectors unplugged...i pulled the connectors off and measured from the plug to the fuse block...ill try to start it tonight with the injector unplugged when i get home...thanks for the help...
-mark
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
-mark
Old Aug 8, 2003 | 07:32 PM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
so i checked the injectors for 12 volts....and both sides had 12 volts...so i tried changing the distributor pickup....and it started ran and drove...then when i shut it off and went to start it back up....once again it has no injector pulse...
Old Aug 8, 2003 | 07:41 PM
72LT1VETTE's Avatar
Engine: 350 HO
Axle/Gears: 336
Sounds like either a faulty ECM or the ignition module in the distributor (is that what you are calling the pickup).
Old Aug 8, 2003 | 07:45 PM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
yea...but i just changed the ignition module.....i put a brand new one in and it fixed it for 5 mins now it is dead again...
Old Aug 8, 2003 | 08:32 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Just for clarity...
Unplug an injector.
Measure resistance on the injector..NOT the plug.
What's the reading?
Do this to all 8 and post....*seems* to me you're reading the plug side, not the injector.
InfernalVortex
Apr 20, 2021 11:31 AM
djmarch
May 8, 2016 11:32 AM
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Hal87
Sep 26, 2015 09:26 PM
Ranbo108
Sep 9, 2015 12:20 PM
