Pro Lightning's straight or angled
Old Dec 7, 2003 | 06:13 PM
Mohammed's Avatar
Car: 88 IROC-Z
Transmission: 700-R4
Searched the board but didn’t get what im looking for.
Pro Topline Pro Lightning 180cc runner 64cc chamber going on an L98 with Hooker 2055 headers.
What should I get them straight or angled?
Thanks,
Old Dec 8, 2003 | 04:14 AM
Mohammed's Avatar
Car: 88 IROC-Z
Someone help please :hail:
Old Dec 9, 2003 | 12:29 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
I have different heads but went with angled.
Old Dec 16, 2003 | 10:56 AM
Mohammed's Avatar
Car: 88 IROC-Z
Thanks mate
Old Dec 16, 2003 | 11:46 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Id get strait plugs, that way you have less of a chance of interference with the headers. I have SLP headers and 200cc Lightnings with strait plugs, I dont believe the angle plug heads would have worked.
Old Dec 16, 2003 | 11:47 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
actually, since the L98 heads are angle plug, most 3rdgen headers are made for them too..........
Old Dec 16, 2003 | 12:31 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
'Angle plug' is a broad term. L98 heads have a unique angle, as do many other aftermarket heads; even if they dont interfere with the L98 plugs theres no guarantee that they wont interfere with other angle plug heads. Im pretty sure the angle on the Lightnings makes plug boot clearance impossible. Either way, theres no real point to chancing it, angle plugs really offer no benefit anyway.
Old Dec 16, 2003 | 03:41 PM
Mohammed's Avatar
Car: 88 IROC-Z
Now I’m confused I’m really ready to order but don’t know what to get angled or straight.
Old Dec 16, 2003 | 04:27 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
I need to know too. I have 2055's and am planning on ProTopline 180's as well, so I definitely need to know this.
Old Dec 17, 2003 | 07:01 PM
Mohammed's Avatar
Car: 88 IROC-Z
bump :hail:
Old Dec 18, 2003 | 01:38 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Cannot answer your question, but I had angled (NOT L98 angled there is a diff. ) and it didnt clear my SLP headers, now I've ordered straight heads.........
Search the archives! similar questions have been up before
/N.
Old Dec 18, 2003 | 09:11 AM
11sORbust's Avatar
straight plugs will be better. Even then you'll want to buy some accel shorty plugs...
Old Dec 18, 2003 | 09:18 AM
11sORbust's Avatar
Bahrain???
Is that where your beautiful car is at?
Old Dec 18, 2003 | 11:18 AM
Mohammed's Avatar
Car: 88 IROC-Z
Originally posted by 11sORbust
Bahrain???
yep
It was imported from the states in 2000 and since that day it’s my sweet ride. Local dealers didn’t have IROC’s in there show rooms only RS and Z28’s. All IROC’s over here are American imports :lala:
Old Dec 18, 2003 | 09:02 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Just my 2 cents... I have Dart Iron Eagles with straight plugs. They barely fit with my SLP 1-5/8 headers. Unfortunatley I have no idea where the angled plugs would point.
Old Dec 18, 2003 | 10:27 PM
11sORbust's Avatar
yep
You are very lucky! I bet you get alot of people looking at it. So camaros are very rare in your country? very cool... Did you have it shipped over or did you find it?
Old Dec 19, 2003 | 10:12 PM
Mohammed's Avatar
Car: 88 IROC-Z
Camaros are never rare they are so popular over here, IROC's are rare especially clean ones, but the streets are fully loaded with LT1's and LS1's. Yes I had it shipped to Dubai and drove it for 12 hours to Bahrain :lala:
Old Dec 20, 2003 | 10:13 AM
11sORbust's Avatar
Really?? That is crazy! I didn't think there was too many f-bodies round your way. Your IROC looks much better than the 4thgen camaros.
Did it cost alot to get it shipped out to you? What is the history of your car. It was from the states?
Old Dec 20, 2003 | 10:13 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
I should clarify that I went with 'L98 angle plug' on my AFR heads.
Old Dec 21, 2003 | 08:56 PM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
Go with the angled ones the straight ones (stock) will suck to change. The angle gets them away from the header tubes and makes changing plugs a lot easier.
Old Dec 22, 2003 | 09:50 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Just to clarify, stock L98 plugs are not straight, and the straight-plug Lightnings have the plug angled down to clear the header primaries. If you guys have so much doubt about what to buy, just call ProTopline or one of their distributors.
Old Jan 8, 2004 | 08:30 PM
Mohammed's Avatar
Car: 88 IROC-Z
I emailed the tech support on summit. For guys who wanna know angled or straight with the Hooker 2055's, Kip from summit:
Response (Kip) - 01/08/2004 08:20 PM
The angled plug heads are meant to put the spark kernel more towards the middle of the combustion chamber for a more even burn. Unfortunately, many headers will not fit with this design of spark plug location. The headers that you have will work fine with the angle plug heads. In this case, I would suggest going with the angle plug heads.
Thanks,
Kip
Old Jan 9, 2004 | 12:21 AM
85TransAm406's Avatar
Car: 1985 Trans Am
well, from what i've seen, angle plugs only seem to help with flame characteristics in a domed piston application. But the best bet is L98 angle, if available. Most headers for 3rd gens i've seen clear better with that angle. I had L98 heads and sportsman II straight plugs with the same headers (hooker 2460s). The straight plugs clear, but the L98 ones did better.
Old Jan 9, 2004 | 10:13 AM
Mohammed's Avatar
Car: 88 IROC-Z
So will it be fine using straight with the 2055’s
jbates346
Oct 21, 2015 01:50 PM
tmellott89
Oct 14, 2015 02:06 PM
djmarch
Oct 2, 2015 10:41 PM
mfp189
Sep 27, 2015 09:25 AM
FED 387
Sep 16, 2015 12:18 PM
