bought a set of accel runners and.......
Old Dec 23, 2003 | 01:07 AM
ray royer's Avatar
i have a 86 iroc and i bought a set of accel runners and there is no where to put the injector that goes into the stock runners. i believe its a start up injector. anyone know what to do?
Old Dec 23, 2003 | 06:05 AM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
welllllllllllllllllllllll. i would say either swap up to the 88-92 setup, and chip, or sell/trade off and get the early type of runners. shawn
Old Dec 23, 2003 | 11:07 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
All you have to do is remove the cold start injector, cap fuel rail, and run a chip (memcal/PROM) from an 89 IROC.
Then you could use those runners.
Old Dec 23, 2003 | 01:41 PM
85TransAm406's Avatar
Car: 1985 Trans Am
well, that and he would have to have a chip burned that would eliminate the VATS
Old Dec 23, 2003 | 03:00 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
If the runners are brand new, send them back and get the right ones. Otherwise, do as stated and get a chip burned and block off the fuel feed for the CSI.
Old Dec 23, 2003 | 03:44 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
It's better to just eliminate the Cold Start Injector and use the new runners.
Then you could use a WAY better .bin like (ARAP.bin) with VATS turned off.
The above is what I would do.
Old Dec 23, 2003 | 07:19 PM
Morley's Avatar
ARAP would be a horrible bin for a stock 305 TPI.
There is another solution, one that I have done myself.
Very carefully measure out the location of the 9th injector from the bolt hole it uses in your stock runners and the depth of the large hole.
If you look at the backside of the flange on the new ones you'll see that some of the passage for the CSI is there.
Now transfer your measurements to the new runner. Drill about a 5/32" hole where the center of the CSI is going to sit. Next counterbore a 7/8" hole to the depth measured above. If you don't have a counterbore you can use a "speed bore" bit, the flat ones used for boring large holes in wood (Yes, it WILL cut the alumnium without a problem)
Next measure the smaller part of the hole where the tip of the CSI stick through the flange and drill your 5/32" hole(whats left of it) up to that size.
Viola! one CSI equipped runner.
Old Dec 23, 2003 | 10:43 PM
ray royer's Avatar
thanks for the replys. i was thinking of selling these and getting a set of asm ltr's because i like the way they look. any advice of which one is better. accel or arizona's. i'm gonna run the accel base ,ported plenum, ported heads, and a nice cam, and all the bolt ons. if i wanted to run the injectors that come in the 350's could i just swap computers from a 350 iroc with maf. and would a 52mm t-body benefit this set up.
tazs2000
Jul 15, 2017 08:44 AM
evilstuie
Feb 28, 2016 03:33 PM
86IROC112
Sep 7, 2015 01:37 PM
fcorallo
Aug 20, 2015 11:28 PM
johanlindgren
Aug 16, 2015 12:16 AM
