ls1 cold ait lids on thirdgens???
Old Feb 24, 2004 | 02:45 PM
dcm01003's Avatar
Car: Black 89 Camaro RS w/t-tops
Engine: 2.8L (173ci) v6
has anyone ever tried to retrofit a ls1 cold air lid into a thirdgen in place of the stock air intake?
Dave M.
Old Feb 24, 2004 | 02:59 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Fatal88 has. But, his car has a whole 4thgen front clip (from firewall to core support) with 3rdgen fenders and bumper hanging on the 4thgen clip. Not to mention, he has a LS-1 in there too!
Old Feb 25, 2004 | 12:59 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Extending on this topic, why are there no aftermarket airlids for our dual snorkel intakes? I find it hard to believe the stock lid is optimally designed.
Old Feb 25, 2004 | 09:26 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
It's not necessarily optimized, it's just all GM could fit in that section.
Old Feb 25, 2004 | 01:57 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Depends what you mean by optimized. The stock camaro air cleaner isn't even a minor restriction until you are well into 12s. It's not a bad piece by any stretch of the imagination. Other than that, as already said, it's also about as tall as possible for fitting over the core support and under the hood.
Old Feb 25, 2004 | 02:18 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
You can always help the stock TPI lid a bit by doing what I did:
Old Feb 25, 2004 | 02:19 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Old Feb 25, 2004 | 04:07 PM
dcm01003's Avatar
did you buy that setup or make it yourself?? and if you made it yourself what did you use and what are the measurements of the pieces?
Dave M.
Old Feb 25, 2004 | 04:31 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
No s*** 1bad91, I am one of the people awaiting your ABS plastic ram air boxes
Get those made!!! I want them! lol.
I see. So basically it is true then that with cut airboxes and true ramair, the stock dual snorkel intake is good for very serious numbers?
Old Feb 25, 2004 | 05:46 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I brought the measurements / design to a metal fab shop and they fabbed them up for me. I'm currently making sets of these boxes out of ABS plastic for several board members. But dont reply to this thread about that. PM me if you need more information.
Yes, with lower filter housing to grill ducts and gutted lower filter housing, the TPI air lid setup can supply plenty of air for a healthy small block.
Someone here on Thirdgen.org did a test a long time ago with something similar and the guys car only lost like 3 - 5 rwhp with the air lid setup vs. no lid at all (open throttle body). Which I think is great, because a Firebird typically loses ALOT more when their air filter piping / snorkle is attached VS. open Throttle body.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
NBrehm
Aug 25, 2015 11:49 PM
kyle5647
Aug 15, 2015 11:56 PM
