im scared!!!
Old Apr 15, 2004 | 01:49 AM
TPIMarow6.6's Avatar
Car: 85 Camaro Z-28
Engine: 6.6
Transmission: 5-speed
im scared!!!
Im about to do a 85 Carb to 87 TPI swap(LT1 intake) and im sooo scared that i might mess up the wires on it or not put on the right grounds or something,i was wondering if i messed up on a few things would i be alright or would i ruin alot of crap....im just running a performer intake and stock Q-jet(not tuned) on my car right now.with the LT1 intake i would think i could gain 20hp with it....but who knows....my 406 is begging for it!!!!! please any help would be greatly appreciated!
Old Apr 15, 2004 | 12:27 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
if you dont think you can do it because you dont feel comfortable doing it, have someone else do it because, whatever can go wrong, will go wrong. if you dont think you can do it, pay someone to do it... that way if they mess up, you dont have to pay them until they get it right.
Old Apr 15, 2004 | 10:13 PM
Car: 85 Camaro Z-28
Engine: 6.6
lol, i think im very mechanically enclined but if it comes down to me messing it up or not knowing right away what to do, couldnt i just put a non computer controled HEI distributor in and run the car like that with no electronics hooked up(with the carb setup) i have about 99% of everything i need to know for information wise, as for parts i have everything.
Old Apr 26, 2004 | 12:48 PM
VetNutJim's Avatar
Car: Different One Every Day
Engine: LS1,LS6,L98,L83
Transmission: 700R4, 4060E,Turbo 350, Turbo 400
You won't fug up. Go ahead and do it.
It's just about all "idiot proof" (Not saying you are one) jsut encouraging you to do "what you wanna do".
Plan it ALL out ahead of time. Install all the components you can ahead of time.
Install all the wiring/fuses ahead of time.
Install the fuel pump,fuel lines/filter/return line ahead of time.
If you do all these things FIRST, you can drive your car around right up until you make the changover with minimal downtime.
BTW, you can use an inline pump, no problem.
I used the MSD pump from JEGS, about 99 bux and it comes with a FREE 'yeller' hat!
Other than installing a turbine engine in your car, this is the BEST thing you can do for it.
GO FOR IT!!
Old Apr 26, 2004 | 01:16 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Just make sure to check, double check, and check everything after you are done. The swap isn't too hard as long as you are dealing with good parts and the right harness it is almost as simple Plug and Play Ok maybe not quite that easy just be sure to take your time and pay attention to detail when routing wires. Wire ties come in handy and running the Harness correctly and cleanly will help later on when trying do stuff, Hunting through a birdsnest of wires suck so make it a clean install.
just my .02
Old Apr 27, 2004 | 12:16 AM
Car: 85 Camaro Z-28
Engine: 6.6
cool, i picked up the spade connectors, everything does seem to be like it will be fairly easy, the harness is still wrapped from the factory so i dont think ill have a rats nest problem but hopefully this will make my 400 get up and go. lol if i have any problems ill be sure to post it, also about the fuel pump, i have the 87 pump gastank ect....
Old Apr 29, 2004 | 01:22 PM
VetNutJim's Avatar
AHhhhhh!!!
You ALREADY have a pump in the gas tank. DOUBLE COOL.
You ALREADY have a return line then.
More than HALF the pita work is done then.
Doit,doit,doit.
I didn't have a pump or a return line on my 73 Chevy Truck.
Had to run lines, remove the tank, etc,etc, PITA but I HAD to have TPI!!!!!!!!!!!!!!!!!!!!
and I GOT it. woohoo.
Old Apr 29, 2004 | 10:59 PM
Car: 85 Camaro Z-28
Engine: 6.6
well i have to put in my 9 bolt posi still....and some guy is looking for a T-5 and will trade his T-10 for it so i dont know. im thinking about that transmission because its stronger, but id really like to get a 6-speed, but with my 400 "youd have to buy a special flywheel made for one peice RMS" well that adds up quick especially a price of already 1-2k.... i dont really know what i should do with that. but i think i am all set to be able to put the fuel injection on my car... i wonder how much more power i will be gaining from the LT1 intake(dyno'ed about the same as an accell system) going from my basically stock intake setup, down to the air breather lol! any opinions?
Old Apr 30, 2004 | 09:00 AM
VetNutJim's Avatar
I just removed my 31 year old Q-Jet and replaced it with TPI.
It's a WORLD of difference.
The whole engine operation/power application is sooooo much more smooth.
It pulls a LOT harder too.
It's probably about the equivalent of going from a 2 barrel carb to a 4 barrel carb but better.
I can FEEL a SUBSTANTIAL increase in power and torque.
Wish I had done this long ago......
NEXT is replacing the 350 Turbo-Hydramatic with a 700R4.....
Old Apr 30, 2004 | 12:36 PM
Car: 85 Camaro Z-28
Engine: 6.6
i hope you put in a good 700r4 cause most of them go to bad or arent that good. but if you had a rebuilt one or something id say go for it.....
New2Chevy
Sep 28, 2015 12:35 AM
88greyiroc
Jul 25, 2001 11:32 AM
green_is
Apr 9, 2001 03:09 PM
86FyrBrd
Apr 5, 2001 11:47 AM
3504mula
Feb 8, 2001 10:37 AM
