52mm throttle body
Old Apr 24, 2004 | 03:00 PM
mdhoward@family's Avatar
52mm throttle body
How much will a 52mm throttle body improve the performance of a stock 5.7 tpi?
Old Apr 24, 2004 | 03:13 PM
OMINOUS_87's Avatar
Highly doubtfull.
Spend your extra funds elsewhere.
Old Apr 24, 2004 | 04:57 PM
Morley's Avatar
Before trying to get more air into the engine you have to make provisions for getting it out, ie: headers, high flow cat, 3" cat back, low restriction muffler. Then you'll need to work on the intake, (TPIS bigmouth/ LPE), bigger runners, ported plenum, then finally a larger TB.
Old Apr 24, 2004 | 05:12 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
When I installed a 52MM Edelbrock/BBK TB on my Car....it made a very noticable difference. The throttle response soooo crisp...and the power is just right there. But along with the 52MM TB...I do have Ram Air Boxes, Headers, UnderDrive Pullies, 3 inch FlowMaster Exhaust.....all of those goodies...I would never say "they aren't worth it".....it's just that alot of the other bolt on's help and they work together.
Old Apr 24, 2004 | 08:02 PM
OMINOUS_87's Avatar
84customZ28
I am lovin that pic you got!!!!!!!!!!!! In the sig.
Check here to see how far a 48mm TB will go.
Runnin hard with the stock 48mm TB
Old Apr 25, 2004 | 01:37 AM
Engine: 5.7
thanks man
I know how far a stock 48MM TB will go....but...maybe my car is just a factory freak and accepted the 52MM TB? because..on the butt dyno...it helped out majorly. The only reason I went with a 52MM is because I got a heck of a deal on it....they are usually over $300 new....I got mine used for $150.00....half the price
Old Apr 25, 2004 | 09:44 AM
OMINOUS_87's Avatar
The butt dyno very well might recognize a differnece. This would most likely be that since the TB blades are bigger they will allow more air in for an eqaul amount of movement, more air for eqaul movements means more power sooner.
However at WOT the engine will only require X-amount of air. On the stock or lightly modded setup I highly doubt the motor will out flow the 48mm TB under WOT.
Old Apr 25, 2004 | 11:40 AM
Engine: 5.7
I agree with that
But just the sensitivity and response of the throttle I imediately noticed
Old Apr 25, 2004 | 12:58 PM
OMINOUS_87's Avatar
:werd:
Old Apr 26, 2004 | 02:27 PM
OneBadZ4U's Avatar
Car: '86 Iroc, '87 Iroc Vert
Engine: 350 TPI, 305 TPI
Transmission: T5 in both
Axle/Gears: 3.73, 3.45 both LSD's
I am not a "technical" person, so here's my two cents. When I put on my 52MM Throttle body, I felt the one of the biggest(IMO) increase in power of any other bolt on I had done. My car was finally running the way I thought it should. But like everyone else has said, I already did the exahaust, hand porting of the intake, injectors, pressure regulator, cam, ect. So lay the foundation and then get the throttle body. You'll be very happy you did.
Rob
Old Apr 26, 2004 | 02:48 PM
Engine: 5.7
well put my friend..well put
Old Apr 26, 2004 | 04:34 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
You dont have to spend $300 for a 52mm, you can also buy a bored-out stock style TB if you want.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
