How Fast???
How Fast???
HERES ON FOR YOU GUYS. I JUST GOT AN 85 TRANS AM 305 TPI 700R4, YADA YADA YADA. FROM WHAT IM DOING TO THE CAR I WOULD LIKE TO KNOW IF ANYONE HAS A CLUE TO ABOUT WHAT KIND OF HORSE POWER AND TORQUE MY TA WILL MAKE AND AN EST. 1/4 MILE TIME.
MODS ARE:
REBUILDING THE 305: (FULL STOCK REBUILD FROM PISTONS, NEW BEARINGS, ETC. )
CUSTOM CONE FILTER FOR INTAKE
REPLACING CAM WITH COMP CAM 218 224 114 LSA
I GOT THE KIT THAT INCLUDED THE VALVE SPRINGS TIMING SET ETC. I GOT THE FPR FOR THIS ALSO
TORQUE CONVERTER WITH 2800 STALL
HEDMAN HEADERS LONG TO A 3 INCH CATCO IN AND OUT 3INCH ALL THE WAY TO THE BACK.
FAST CHIP TUNING
ACCELL CAP ROTOR AND IGN COIL
NEW WIRES NGK PLUGS, NOW O2 AND LOTS OF NEW PARTS.
MODS ARE:
FAST CHIP TUNING
You'll prolly run low 15's high14's......
what you really need is 52mm TB edelbrock intake and runner's a 292*dur.525lift. cam and 335 stroker kit with some 3.73 gear's...
tne you'll run mid 13's - mid 12's....
I'd also get some RPM performer Center bolt head's the 60.5cc set...
But then again what would I know...........
my TPI car's Tend to be Slow any way......
it seem's TBI and MPI work best with me...
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Are you running stock heads? If so that cam is to big for your 305 IMHO. What is the lift on the cam. Again if the heads are stock you might have clearance problems.
Another question. I assume you are running speed density with the cone airfilter? In a 3rd Gen. I'am not sure that is the best way to go as you will be sucking in hot air. A lot of us have spent extra bucks to get a cold air intake system. Just some things to think about. Anyways good luck with your project. Allen
keep the faith and Keep working on it . them LB-9's aka 305TPI's will run just as fast as the L-98's can if not faster in some cases...
i had an 87 Z-28 with a 335TPI stroker and i could stay with the LT-1's most of the time and beat them the rest of the time.......
I didn't alter any thing else just swapped in a 400 crank and bord it 30 over...... and i swapped my 2.73 gear's for 3.08's as i already had them............
That Damn Z-28 handed my 87 GTA it's tail light's.......
but the girl i sold it to swapped the 3.08's for some 3.42's and put a 52mm TB on it with the edlebrock intake and runner's and a 75 shot...
so i'm sure it might even of beaten my 91 GTA's old 350TBI and 3.73's........... but i'll have a 406MPI soon enough.......:hail:
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
I think you can run in the mid 14's to maybe low 14's if your lucky. The car started life as a low 15 second car. It all depends on how you drive, shift points etc...
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
what gears you running ......you are going to need at least a set of 3.42's . Something you might wanna look ingto is the fact ....thats a bit of duration for the street ......tuneing is gongi to be important to your success
I say mid 14's
I say mid 14's
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
whats up jfreeman
i wouldn;t bother with the stroker , put in a comp extreme energy 212-218 449 456 112lsa , with comps kit , get your 416 heads ported and polished with bigger 1.94 intake valves , good exhaust , headers, and tune it up ,
i did all of this stuff to a stock 18 000 mile 86 transam , and my car flys now , its unbelievable the get up and go it has now , also i have not yet got the chip correct for this car i am still using the hypercrap chip and it runs that good
good luck and have fun
Car: 1985 Iroc-Z
Originally posted by mikobu3
whats up jfreeman
whats up jfreeman
but i think it's a bit too radicial for a TPI set up....
But i'm sure you could get like 380HP for 2,400 building it your self......
I paid $1,800 for mine it made 285hp@4750rpm & 403Ftlb@3275rpm.
sreZ28
Oct 22, 2015 08:21 AM
