Throwing a code 43 and.... 54????
Old Jul 5, 2004 | 12:41 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
whats a code 54?
in my chiltons a 43 said something like ESC ?
im lost...
i just put in a new fuel pump, fuel strainer, fuel filter, and Idle Air Control motor. my car is a 305 TPI 89 Iroc-z. new MAF.
it refuses to run properly, i can run it for 10-15 minutes around town, then after that it refuses to start properly....
Old Jul 5, 2004 | 08:30 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Code 54 is fuel pump circuit. Reset the ECM and test again. It will be in there from memory before you changed the pump. If it comes back make sure you here the pump run for 2 seconds when you turn the key on but not starting the engine.
Did you adjust the new IAC? You should have. After you adjust it you have to reset the TPS as well. Here's the procedure.
https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
Old Jul 5, 2004 | 08:51 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello HamSpiced,
Code 54 is low voltage to the fuel pump circuit.
Old Jul 5, 2004 | 12:59 PM
HamSpiced's Avatar
Originally posted by Trickster
Hello HamSpiced,
Hey man,
Yea i know thats what it is... but i dont understand how to fix it....
Old Jul 5, 2004 | 01:16 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally posted by HamSpiced
Hey man,
If you want, I can post the troubleshooting tree for you to check your system.
Old Jul 5, 2004 | 04:24 PM
fireball451's Avatar
Car: 91 Z28, 91 Z28, 92 Z28
Engine: LB9, LB9, L98
Transmission: T5, T5, 700r4
Axle/Gears: 3:42, 3:42, 3:23
My code 43 on my first 1991 Z28 305tpi was a bad knock sensor.
My friend had a code 54 on his 1992 formula 5.0tbi. He had a bad fuel pump relay.
Best bet is to go through a diagnosis flow chart to help track down the problem.
Old Jul 5, 2004 | 09:46 PM
HamSpiced's Avatar
yes please do... i tried to search and and i couldnt find it.... go figure...
Old Jul 5, 2004 | 09:55 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No problem dude, here it is and good luck.
Old Jul 5, 2004 | 09:56 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Page 2
Old Jul 6, 2004 | 12:03 PM
HamSpiced's Avatar
so far everythings checked out good.....
im starting to get confused.....
Old Jul 6, 2004 | 02:36 PM
HamSpiced's Avatar
ok so i replaced the cap rotor and plugs hoping it was just somethnig like that...
well of course i was wrong... i can get the car to occasionalyl start, and i can get it to do a low accelleration from 1k to 4k and back down, however i cannot tap the gas....
provided is a video of me doing just that...
http://s92002946.onlinehome.us/Videos/Car.wmv
a slow 4k climb and slow back down again, and then a tap of the gas pedal.
it dies completly..
if the code 54 is what is causeing it, and im getting a headache reading the diagrams and trying to understand what a ckt 465 or 450 etc is what are the most common "gone wrong" things that cause this?
Fanatic1074
Oct 3, 2022 05:57 AM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
Bigold4x4
Sep 28, 2015 05:21 PM
ndndndnd
Sep 28, 2015 08:00 AM
