Accell 24lb. issues?
Old Feb 14, 2005 | 02:27 PM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
Anyone have problems with Accel Injectors? If so, what kind?
Old Feb 14, 2005 | 03:44 PM
blackroc68's Avatar
I did I bought a brand new set of 24# accels. 2000 miles later 1 shorted out and filled my motor up with fuel.dont know long term damage to my motor.Its your motor but i wouldnt want to gamble by using them.Im using 24# ford motorsports.
Old Feb 14, 2005 | 04:08 PM
Car: 1987 Iroc-z
How much did you pay for those Ford's?
Old Feb 14, 2005 | 05:55 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
The FMS 24#/hr injectors are about $210 at Summit Racing. That is what I have been using for about 7 years now.
Old Feb 14, 2005 | 06:14 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
SLP has 25#/hr (rated at 43.5psi) injectors for only $99.95...
Old Feb 15, 2005 | 04:31 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I have some accel 26# injectors sitting on the shelf. Never could get my car to start and run consistently with them so I bought 30# SVO's. Anyone want some 26# accels?
Old Feb 16, 2005 | 12:16 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Old Feb 16, 2005 | 01:23 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
yep you'll find many people who dislike accells I was happy with mine until the took a crap on me a year after I got them but I guess they lasted longer than most on these boards
Im not to fond of putting ford stuff on my car(yes Im one of those people) so when it's time to upgrade I'll be getting something other than ford
Old Feb 16, 2005 | 01:50 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
[Morley] You are mistaken, Accel produces nothing but immaculate and superior injector sets. If you hear anything other than that ignore it, it is a lie or misinformation from ignorant children. [/Morley]
https://www.thirdgen.org/techbb2/sho...hreadid=271828
Couldn't resist.
Old Feb 16, 2005 | 02:20 AM
kairles's Avatar
Engine: 383/LGX
Couldn't resist.
wow he sounded like an accell rep or maybe his last name is Gasket
Old Feb 16, 2005 | 09:49 AM
Car: 1987 Iroc-z
What I would like to know is how did your car react to a bad injector. I fired up my car with a brand new rebuilt 355 and all the mods in my signature. Yhe car ran smooth as silk. The the idle kept getting worse. I stutters a little bit like a mis. I am thinking that maybe this is a bad injector issue after checking a lot of other possibilities. The car deosn't want to start cold, I have to work the peddle until it warms up. Can anyone with a bad experiense tell me if they had smilar issues?
Old Feb 16, 2005 | 12:58 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
https://www.thirdgen.org/techbb2/sho...highlight=accel
some more people out of the closet with accel...
Old Feb 18, 2005 | 12:28 PM
Car: 1987 Iroc-z
OK guys, do the Ford SVO's use the stock clips?
Also, guys are talking about LT1 injectors - any info?
Old Feb 18, 2005 | 08:54 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
yes direct bolt in...
no modification required
Old Feb 19, 2005 | 10:22 AM
smithtc's Avatar
I swapped a set of 23lb/hr rated Accel injectors in my high mileage car because the stock ones are old and not worth rebuilding...leaked, etc. Swapped the Accels in and took it to the track. Better throttle response, new best times in the 8th, car ran well...happy. After about 2 weeks...car starting missing/skipping some, and generally not running as well. Swapping plugs didn't help. Could smell gas so primed fuel rail, and discover that 2 of my Accel injectors were leaking FROM THE BODY. Sent them back to Jegs for refund. Car ran better with the old 200K mile stock injectors.
Just today, I'm putting Ford SVO 24# injectors in. They snapped in nicely, and fuel rail tightened down fine. I think over half of my stock injectors were leaking...but at least from where the fuel was supposed to come out.
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
BAMiller
Sep 14, 2015 06:38 PM
TheTraut88
Sep 11, 2015 05:16 AM
toronto formula
Sep 10, 2015 07:31 AM
Fronzizzle
Sep 8, 2015 12:10 PM
