Accel 58mm TB problem
Old Jun 27, 2005 | 06:09 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
My throttle body will not bottom out causing my car to idle high.
I have tried adjusting the shaft but no help. The spring is good and it snaps back hard. Any Ideas?
Old Jun 28, 2005 | 06:26 PM
92RS3.1L's Avatar
Car: 91 Z28
Engine: Rebuilt and modified 350
Transmission: rebuilt T-5
I'd trade it in for a different one. I'm not sure what you are running, but 58mm is overkill unless you have a HIGHLY modified engine.
Old Jun 29, 2005 | 04:35 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Sounds like you need to adjust/calibrate the IAC.
Old Jun 29, 2005 | 09:36 PM
brutalform's Avatar
According to his profile a 6.6 liter (403 ci) if that is the correct displacement, is enough to use a 1000 cfm TB, IMO.
Old Jun 29, 2005 | 09:37 PM
brutalform's Avatar
Never mind, my goof. I see he has 2 engines listed there.
Old Jun 29, 2005 | 09:47 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
plug the iac and see if it will start.
Old Jun 30, 2005 | 04:14 PM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
I'm pretty sure its the TB because when the idle goes up if I push
on the part where the throttle cables hook up the idle goes down.
Old Jun 30, 2005 | 04:56 PM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
People always say this maybe it's not needed but when I ported my plenum and installed it my throttle response improved a lot.
It gets up quiker than it ever did before. It may not do much up top but I think it was a mod that was worth it.
Old Jun 30, 2005 | 05:58 PM
92RS3.1L's Avatar
Car: 91 Z28
That could be the case. My car when I bought it was a 305 TPI, and it had a BBK 58mm throttle body on it. Sure it was overkill on that engine, but I didnt spend the $200+ on it.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
BAMiller
Sep 14, 2015 06:38 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
