no fuelpressure need help
Old Jul 8, 2005 | 02:53 PM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Hi!
I was out for a drive at the wordslargets "big powermeet" in sweden and the engine stoped,it only runs at idle when i was open the trottle it just died.
Then it started for a short while but died again and after i got it home by lift i checked the fuel by loosing the fuelline before the tb and started,and it comes fuel,but i dont now if it getting any pressure,i cant get the fuelpressuremeeter to give any result.
So tomorrow i am going to check the fuelfilter.My questin are if there could be the fuelpump it self,it is just a year old,i alsoe have the bbk adjustebel fuelregulator and when i was dropping the fuelpressure the car get started but dies if i open the trottle,please help if you have any suggestions.
Thanks!!!
Old Jul 8, 2005 | 08:25 PM
Vader's Avatar
Attach a pressure guage to monitor fuel pressure, then adjust the regulator as necessary to reach 37 PSIG, +/- 3 PSIG (2.55 BAR, +/-0.2 BAR) pressure while the engine is running. If the pump cannot maintain 37 PSI, there may be a filter and/or pump problem, or possibly a regulator.
Old Jul 9, 2005 | 12:11 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Re: no fuelpressure need help
Originally posted by Firebird sweden
Hi!
Thanks!!!
sounds like the Mass Airflow Sensor--I had IDENTICAL problems like U once--it needed replaced--ran great and still is!!!
Old Jul 9, 2005 | 01:24 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
I am going to remove the regulator becouse i have read that it could be a peace of gasket in the regulator which is blocking the fuel.
Old Jul 9, 2005 | 01:25 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
By the way i am running SD.
Old Jul 9, 2005 | 07:11 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
OOps--sorry--I'm not familar with that system, but maybe that some kind of clue!!!- maybe it's not a fuel delivery problem--maybe what ever is the equal to the MAF in a SD system is acting up??? It's worth at least checking--right?
Old Jul 10, 2005 | 11:15 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Hi!
Ok today i have removed the incoming fuelline and i can hold my finger on it and the pressure dont seemes to bilding up any power, so tomorrow i am going to order a new intank fuelpump from holley that can get up to 90psi,not that i need it but you dont wont to drop the tank every day.
I will also install the holley fuelpressure regulator becoue it semes to be easier to adjust.
I cant think that it can be anything else anyway,can you?
Thanks!!
Old Aug 16, 2005 | 05:08 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Hi!
I am just going to tell you what cause the problem.It was the short rubber fuelline in the tank between the pump and the hard lines that has a small crack in it,very hard to see,just to let you now.
Thanks all.
Old Aug 20, 2005 | 08:53 AM
Vader's Avatar
Thanks for the update. It's always good to get feedback about the solution.
I've had the same kind of problem occur. I trust your now adequate fuel pressure is allowing you to drive the car as it was intended.
Old Aug 20, 2005 | 10:34 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Yes!
And i set the puelpressure at 50psi and no problem at all,alsoe i am going to install a fuelpressure meter at the fuelline so that i can check the pressure as often i like.Alsoe i am going to install a Holley stealthram intake this winter.
Old Aug 20, 2005 | 01:29 PM
Pat Hall's Avatar
A good Swedish winter ought to give you all the time you need to do a stealthram install!
Theking
Feb 15, 2008 02:43 AM
Theking
Feb 14, 2008 12:49 AM
Theking
Oct 16, 2007 12:37 PM
Spitfire
Oct 13, 2005 01:52 PM
Firebird sweden
Jun 25, 2003 04:34 PM
