injectors not priming???
Old Jul 12, 2005 | 11:44 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
when i turn the key on my 89' firebird 350 TPI, usually the 2 things i hear are the fuel pump turn on, and the injectors prime... im not hearing the injectors prime anymore, and the car will not start unless i spray carborator cleaner in the pcv valve. so i know its a fuel problem. what could be causing this problem???
Old Jul 12, 2005 | 06:32 PM
My1986IROC-Z's Avatar
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
Have you replaced the fuel filter, could be clogged?
Can't you take a fuel pressure reading to see if you are getting fuel to the rail from the pump. I would start that way or actually try to get a fuel pressure reading first and then you'll know if the filter is flowing freely. My 2 cents from the beginning shade tree mechanic
Old Jul 12, 2005 | 09:20 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I never heard of injectors "priming". When you turn the key to the ON position, the fuel pump turns on for x seconds and the fuel rail is pressurized to the set pressure.
There is no such thing as priming the injectors.
Old Jul 12, 2005 | 10:20 PM
Abubaca's Avatar
I've never heard of injectors priming either. The priming is the system pressurizing, but what you hear is the pump.
...the symptoms do seem fuel related though.
Have you tested with a noid light for injector pulse?
Old Jul 12, 2005 | 10:50 PM
flowmasterchevy's Avatar
Car: '91 RS, F41
Transmission: WC T5
doesnt the relay click when the pump cuts off? that may be what he was hearing...
Old Jul 12, 2005 | 11:25 PM
bigchief's Avatar
no no, my injectors would make like a whining noise when i turned the key along with the fuel pump noise. so i think they arent getting the signal to pulse or whatever anymore for whatever reason. im gonna get another computer tomorrow and see if that fixes the problem, maybe the computers not telling them to turn on or some crap..... ill keep you guys posted, thanks
Old Jul 13, 2005 | 12:40 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Injectors don't pulse or whatever at key on - engine off. You were probably hearing fuel going through the rail.
You're problem could be a VATS problem.
Could be REF signal from distributor to the ECU.
Do some diagnostics before throwing more money at it.
Old Jul 13, 2005 | 01:09 AM
bigchief's Avatar
well im just gonna throw antoehr comp in it, cuz its warantee'd anyway so im not paying anything..... might as well give it a try for free yanno
gta892000
Aug 11, 2019 11:16 AM
92-Formula
Dec 12, 2015 10:34 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
