idling and black smoke problems
Old Aug 16, 2005 | 09:08 AM
falak's Avatar
Car: irocz camaro 88
heyyy guys im in dire need of ur help.actually i just rebuild my cars engine and its having idling problems and is giving out black smoke........its a 350 tpi 5.7 helpppp
Old Aug 18, 2005 | 01:15 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Black smoke = too much fuel
check your fuel system, too much pressure, injectors out of ohm range, tps adjustment, iac adjustment, timing adjustment, maybe even a tune up, might have flooded your plugs.
any check engine codes?
Old Aug 25, 2005 | 03:54 AM
falak's Avatar
Thanks for your advise. I am getting two trouble codes from the ALDL connector. One is 2 flash pause 3 flash and the other is 3 flash pause 4 flash. Probably the second trouble code refers to the MAF sensor but not sure about the first one. Also, just found out that the brand new spark plugs have been shorted probably due to flooding. How can i check if it is really the MAF sensor at fault or the relay.
Old Aug 25, 2005 | 03:55 PM
QuickStyle's Avatar
Car: 91 Z28
2,3 code is manifold air temp sensor
3,4 code is mass air flow sensor
i would reccomend you buying a complete shop manual for 82-92 camaros, it will tell you how to check your maf sensor, and just about everything else.
Old Aug 26, 2005 | 04:42 AM
falak's Avatar
Thanks a lot for your help. Since i do not live in the US can you recommend a good service manual and also the source from where it can be purchased and then i will ask one of my friends living in the US to buy it for me. Can you also tell me where i can buy a good code reader.
Old Aug 26, 2005 | 05:01 AM
QuickStyle's Avatar
Car: 91 Z28
haynes is pretty good manual cost $15-$20 at almost any auto parts store. www.autoxray.com is a good place to find a scanner. or you can just do the paper clip trick.
Old Aug 27, 2005 | 10:12 PM
falak's Avatar
thanks alot ill buy it then. im even getting a code,3 flases pause then 6 flashes wat does this mean?
Old Aug 28, 2005 | 04:14 PM
QuickStyle's Avatar
Car: 91 Z28
maf burn off curcuit
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
Fronzizzle
Aug 17, 2015 02:52 PM
squiggy2
Aug 9, 2015 09:30 PM
