Difference in MAF and SD throttle bodies
Old Sep 2, 2005 | 11:20 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Hey guys,
I have a chance to get a 58mm TB for my truck that I switch to TPI on but it is for a 85-88 year model maf camaro but I set my truck up as a 1992 Speed Density camaro. What is the difference in the two throttle bodies? Will it work? Thanks for the help.
Old Sep 2, 2005 | 02:00 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Just talked to Holley tech and he said there is no difference in the two throttle bodies. Answered my own question.
Old Sep 2, 2005 | 03:18 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
The Holley tech doesn't know what hes talking about. The difference isn't a clear cut MAF vs SD thing. Its between 85-88, and 89-92 (89 was MAF while 90-92 was SD).
What year is your plenum? The 85-88 TB will work fine if your plenum is an 85-88 model. It its 89 or later, the 85-88 throttle body will not work well because it lacks the IAC hole in the plenum.
By the way, the throttle cable also changed between the two years.
Old Sep 3, 2005 | 11:16 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I have the StealthRam on my truck and use the camaro throttle cable for it.
Old Sep 4, 2005 | 07:47 AM
S10Wildside's Avatar
Doesn't the 1989 plenum have an IAC hole? It's the only TPI plenum with a perfectly round hole. The 85-88 plenums have a triangular shape hole (sorta). The 90-92 plenums have no hole at all.
Old Sep 4, 2005 | 10:14 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I think the only difference between '89 and '90-'92 is a MAP connection fitting...I don't recall if my '89 had a hole in it or not?...but I don't think it did.
Old Sep 4, 2005 | 11:37 AM
No, the 89 plenum has a small hole in front. The 90-92 plenum has no holes...other than the main two.
Here's an 89 plenum I recently cleaned. I also have a 91 plenum that only has the two large holes.
Old Sep 4, 2005 | 11:39 AM
Here's an 85-88 plenum.
Old Sep 4, 2005 | 12:10 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
the Holley Tech guy said that the 58mm throttle body #112-503 comes with the StealthRam system and it can be used for any setup. So will it work with my stealthram on a 1992 setup?
Old Sep 4, 2005 | 03:39 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
That's odd, since 89 uses the same TB...but it's pretty obvious with your pics posted.
Good info.
specialized
Jun 18, 2022 09:26 AM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
