swapping 305 for 383, identify some parts off old tpi motor
Old Oct 22, 2005 | 06:10 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
three things i need identified right now...there is a black box connected to the pass side of the plenum (pic 1) what is that for?
next is a black piece with a couple vacuum hoses running to and from it (pic 2). its located right next to the coil, what is that?
finally what is the sensor located under the plenum used for?
Old Oct 22, 2005 | 06:11 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
pic 2
Old Oct 22, 2005 | 06:36 PM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
Pic 1 is the MAP sensor and pic 2 looks like the EGR selonoid. It mounts under the ignition coil in the same holes.
Old Oct 22, 2005 | 10:30 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
The sensor under the plenum is a MAT -manifold air temp- I believe. Someone correct me if I'm wrong.
Old Oct 22, 2005 | 11:13 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
yea the first is the map sensor...the heart of speed density
Old Oct 23, 2005 | 10:56 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
im moving to a stealthram setup and that doesnt have an EGR provision so what should i do with the the EGR soleniod?
Old Oct 29, 2005 | 01:23 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
take it out,
and save it in a box of parts,
Old Oct 29, 2005 | 01:32 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
thanx! exactly what i needed
Old Oct 29, 2005 | 02:15 PM
Car: 86 T/A
Engine: HSR 355
I just swapped over to a stealth ram setup- I just took my whole TPI setup off- EGR and all, reassembled it, and have it sitting in the corner of my garage for when I need money or emissions testing.
jhawkeye
May 25, 2022 06:33 PM
st.evel07
Aug 13, 2015 06:15 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
squiggy2
Aug 9, 2015 09:30 PM
1nastygta
Aug 8, 2015 07:38 PM
