Suggestions On A New Distributor
Old Nov 17, 2005 | 08:32 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
My Distributor Messed Up ON My 88 IROC, ANd Now I Got The Money TO Repair It, People I Talked TO Suggest I Keep It Stock, But Then Again I Want An Aftermarket One. So Any Suggestions?
Old Nov 17, 2005 | 08:36 PM
FearThisGTA's Avatar
Car: 1991 TRANS AM GTA
Engine: 5.7L TPI
Axle/Gears: 3.23 Posi
MSD Pro Billet Dist. I have had one since they came out and luv it. Except for replacin the ign mod that was a pita. But it was almost 10 years old and the wires were brittle. BUT still the MSD hands down, well worth the $$$$
Old Nov 17, 2005 | 08:40 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Yeah I Replace My Ignition Module On My Car, And It Just Took A **** On Me, Ive Been Lookin Around ANd Ill I Find Are The Distributors With The Vacuum Advance, And I DOnt Want That ****, U Got A Part # For That Msd U Got?
Old Nov 17, 2005 | 11:10 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
msd pro billet i love mine especially the one piece design.
i paid $400 for mine i believe, cheaper than an oem gm one which are crap
Old Nov 18, 2005 | 06:40 AM
CrazyHawaiian's Avatar
Car: too many ...
I think your car uses EST so you need a distributor that will work with EST if you want it to be drop in bolt on. A re-man OEM replacement can be had for $110 from Autozone or $160 from Checkers. Summit sells a "Summit Brand" distributor blueprinted up to 6500 rpm for $199. This is the route I would go if needed to upgrade to a performance distributor. Mallory also makes a 80 series that will work, but its expensive. Up in that price range you can also get a DUI distributor, and then there is the MSD route. For my minorly modded IROC (just boltons) the stock distributor should be fine, just using an upgraded coil and stuff.
Sucks that you replaced the Ignition Module and it still didnt work. I'm actually in the same situation right now with my IROC. New distributors will come with another Ignition Module so both of us have effectively wasted our money. But I'm lucky that I was able to find a fairly new distributor used from a friend for cheaper.
Old Nov 18, 2005 | 08:17 AM
Engine: 5.7L TPI
Part # is 8366
Old Nov 18, 2005 | 01:23 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Originally posted by fearthisgta
Part # is 8366
...and this was a bolt in plug right in no wireing or harness hacking ? I want one then
Old Nov 18, 2005 | 02:43 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I have seen many Accel and MSD distributors die for no reason whatsoever. Do yourself a favor, buy a stock replacement distributor. This is from experience and I know many other extremely experienced thirdgen guys (all with 400+ cubic inch motors) that will tell you the same thing. We have tested the aftermarket distributors and they just are not as reliable as a stock replacement. Sad but true.
Tim
Old Nov 18, 2005 | 03:03 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
A D.U.I street/strip unit is the only way to go...you won't need an extra ignition box crap because they have enough spark to light up a block. Each unit is hand built to your specs and you have a choice of red, black, blue or clear cap. I'm running a clear-capped one on my motor now...had it custom curved and I run no spark box junk and that thing fires my motor with spark to spare!
Old Nov 18, 2005 | 09:21 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
If I Go For Stock Replacement It Is Kinda Expensive, And ALl My Car Has Is AFPR, SLP RUnners, Hooker Headers, Catback Exhaust, MSD Blaster Coil.
Old Nov 18, 2005 | 09:43 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Tim
Engine size doesn't mean brain size. I'm not putting you guys down, I'm sure you know your stuff but that's not much of a compelling argument.
I'd bet Accel and MSD distributors can't be worse than $110 reman's from Autozone if that's what you mean by stock replacement. If you meant the real stuff from GM brand new then I'd say you're probably right, that's the way to go if you have the money.
Old Nov 19, 2005 | 05:30 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
good to hear all this . It's just I got this turbo gongi in next season ....so I wasn;t sure if it was up to the task ...
Old Nov 19, 2005 | 08:19 PM
BOTTLEDZ28's Avatar
Transmission: A4
Doesnt Proform sell one for $100 or something? Anyway, I have the MSD pro billet one and I have had nothing but bad luck with it. it is a great dizzy and all but I think Ijust got a bad apple out of the bunch. MSD has a message board over on thier site and you can get some great feedback from others who use this dizzy.
Old Nov 20, 2005 | 02:21 AM
porkyzilla's Avatar
Engine: 5.7tpi 350,
thats wierd i think the msd is better built, ive had nothing but good with mine been over a year with it...
Old Nov 20, 2005 | 09:00 AM
BOTTLEDZ28's Avatar
Transmission: A4
oh I am not saying that Proform is better then MSD or vise versa. I was just simply stating that I had bad luck with the MSD dizzy. MSD has fixed it for me and I would not hesitate to buy another one in future. My vote is for a MSD dizzy. My entire ignition system consist of MSD products.
Old Nov 23, 2005 | 08:37 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
WOuld The Distributor problem make my car have a rough cold start? and it would surely make it run rich right?
Old Nov 24, 2005 | 09:41 AM
BOTTLEDZ28's Avatar
Transmission: A4
no the dist. would not cause those problems in 99.99% of the time. You have a different problem elsewhere in your car that is causing that. Those symtoms can be from a lot of things and pin pointing the cause of the problem may take a bit of looking around. Either do a search for rich or hard start probmes or start a new thread in the Tech boards and someone can help you there.
Old Nov 25, 2005 | 06:53 AM
Engine: 5.7L TPI
Yes, its a simole plug and play. Like I said I have had mine since they were first introduced about 10 years ago and its still GREAT!! I will tell you they use the "FACTORY" ign modules from A/C Delco. MSD told me they could not desipn one that was better than it, so they used it. They said they test them all. They only difference is it take a different p/up assy. I got one from them they mailed to me "FREE" of charge it took a while to get here but I was willin to wait.Like I said before you wont be dis-satisfied. Good Luck.
amargari
Nov 10, 2015 02:09 PM
camarohelp
Sep 22, 2015 03:19 PM
R13_Braz
Sep 18, 2015 05:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
Jlanz55
Sep 6, 2015 03:05 PM
