What's this plug?
Old Jan 4, 2006 | 11:36 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
What's this plug?
I finished doing my heads on my 87 L98 Camaro. Ofcourse the car won't start. I was making sure that everything is pluged in. I noteced this little guy on the drivers side between the valve cover and firewall. I don't remeber disconcting it. But I'm just curious if this could be my problem. I also don't see anthing in that area that it can go to. Also the car is all stock with emmisons still on it. Thanks in advance! Adam :-)
Old Jan 5, 2006 | 12:01 AM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
One of the leads looks pink or partly pink, which is likely switched power for the ignition (coil, module etc...). Check 'round the distributor and related goodies.
Old Jan 5, 2006 | 12:04 AM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Just a wild guess here. It's kinda lard to focus on what shape the plug is,it's not one of the plugs that goes to the back of the distributor is it?
Old Jan 5, 2006 | 12:28 AM
It's pink/black line and the other wire is ether black or brown. It's a two circle plug. I have the two wire's allready plugged into the dizzy. Unless I didn't plug the right one in. But the plugs can only plug into the right thingy, right? Thanks again for the help guys. Adam :-)
Old Jan 5, 2006 | 12:25 PM
Well the car start's now. The dizzy was off. So that plug dosen't have anything to do with it starting. But I would still like to know what it gose to. If a mod dosen't mind. Mabye this can be moved over to the elctronics forum. They might know since this an't a tpi problem anymore. Thanks. Adam :-)
Old Jan 5, 2006 | 06:07 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
As I responded to the other plug/connector question,
I have an unused pink/black two prong connector behind the dvr side cyl head. I bought the car new, am the other owner, dont know what it is supposed to be.
Old Jan 5, 2006 | 06:18 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
That connector attaches to another which plugs into the IAT under the plenum.
Old Jan 5, 2006 | 10:45 PM
The car runs with out a SES light coming on. So it can't be nothing important. Plus I know it's not the IAT sensor. Because I had to take the plenum off after I forgot to plug it in. . Adam :-)
Old Jan 5, 2006 | 10:58 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Under the wiper motor?
Old Jan 5, 2006 | 11:01 PM
Ya it's under the wiper motor I guess. But I allready checked there. Adam :-)
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
