throttle body
Old Jan 31, 2006 | 08:27 PM
Toms88GTA's Avatar
Car: 88 GTA
Engine: L98 350 TPI
Transmission: 700 R4
throttle body
has anyone made the center with the butterfly an oval and make it one piece instead of 2 please give me info if it can be dont or if its dumb
Old Jan 31, 2006 | 10:01 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
That would be a mono blade like an LS1 has, and no i know no one who's done this; it's also probably a bad idea because it would be more work than it would ever be worth.
Old Feb 1, 2006 | 05:13 AM
Toms88GTA's Avatar
Car: 88 GTA
Engine: L98 350 TPI
i have a spare stock throttle body and some free time we ported and polished a stock ls1 TB and it made a worlds of a difference on every type of driving so it might be a project
Old Feb 1, 2006 | 04:09 PM
Sounds like a plan, I know you can open the TB's up to mate more smoothly to the plenum and this could surely help out. What year throttle body do you have? You should port it and take some pics, maybe a sticky can be made of this.
Old Feb 1, 2006 | 04:48 PM
Toms88GTA's Avatar
Car: 88 GTA
Engine: L98 350 TPI
i have a 88 GTA and i got the spare off of a i think it was an 89 formula 350 i was dumb when i took the throttle body i should have taken the hole manifold but i was dumb and when i went back for it they pulled the motor and crushed the car and the motor was sold but im goin to probily take pics when i do it and post them
Old Feb 1, 2006 | 05:13 PM
Shagwell's Avatar
Car: projects.......
TPIS makes the "Monoblade" that you describe. - WHY???? A stock TPi intake flows about 450 cfm, modded plenum w/ aftermarket base and runners abour 650-700ish. So why put a TB in front of it that way outflows(monoblade-1000+cfm) the intake itself. That'd be like putting a Dominator on a iron 2barrel intake. - The stock TB flows 780 cfm. 500hp small blocks are using 750cfm carbs, so I say again, why????The ony possible thing it could do for you is loose throttle response. How's that gonna help?
- not trying to **** on anyone, just stating the facts.
Old Feb 1, 2006 | 05:59 PM
Toms88GTA's Avatar
Car: 88 GTA
Engine: L98 350 TPI
i didnt know all of that info we just port and pollished a stock ls1 TB and it made worlds of a differnce i pulled mine of and there really wasnt much i could do to it and i know i have a spare at home so i thought maybe i can make a mono blade cuz i know that the 52 and 58 mill TB's got for 350$ and up so i thought well if u can make one and it works cool if it doenst o well il put my good one back on and just wait till i build my motor and buy a 58 mill TB but that makes me thing thanks for those numbers
Old Feb 1, 2006 | 06:21 PM
Shagwell's Avatar
- thats cool. I wasn't trying to bash anyone, just trying to put out the facts. - You'll find unless you go over about 550hp(probably more), the stock TB will make just as much power, and you'll have a little more throttle response. - the LS1 is a very different motor, with a VERY different intake...when's the last time you turned your TPI over 6k making power?
Old Feb 1, 2006 | 08:38 PM
Toms88GTA's Avatar
Car: 88 GTA
Engine: L98 350 TPI
umm the last time i hit 6 grand was a the strip in first but other then then not latly. i know the ls1 is totaly differnt everything but my thought was if one little port job helped that much on that i dont see y modding a tpi TB wouldnt do the same. i wont have more then 500 horse for another year so i was just looking for some cheep reactions out of the car for some more fun still in school not much money to play with
Old Feb 2, 2006 | 05:52 PM
Shagwell's Avatar
I'm guessing you have runners/base??? because stock only makes power to around 5k, so 6 would be pointless... - anyhow, if you go to the Holley web-site(or if you have the catalog) they have an equation for cubic in vs rpm = X cfm needed. Although it's intended for carbs, it's basically the same as efi. Actually, efi wouldn't need as much because you're only moving air, not air & fuel...
later, justin...
Old Feb 5, 2006 | 06:33 PM
Toms88GTA's Avatar
Car: 88 GTA
Engine: L98 350 TPI
well since i still have my auto in it it shifter when the computer shifted it but i think i remember it shifted about there it might have been about 55 but i was playing around the other day and it winded up to about 6 right b 4 it shiffter and it still pulled hard in first i havent touched my base plate i dont know if either the guys b 4 me did but i will look into the holley site thanks for the info
tommy
Old Feb 5, 2006 | 09:37 PM
Shagwell's Avatar
an 88 is not computer shifted. A 700R4 is governor shifted. - as for 6k, I'm guessing you're looking at a factoy tach huh? The highest of our stock GM shift points is 5200...That was only usually vette/gta/iroc, the rest were usually lower.
Old Feb 6, 2006 | 01:05 PM
Toms88GTA's Avatar
Car: 88 GTA
Engine: L98 350 TPI
i was told it was computer shifted but learning stuff everyday and yea i didnt put the big **** tach in dont like it makes me feel like im driving a civic and i have a stage 1 hypatech chip that says it takes off governers and rev limiters
Old Sep 13, 2007 | 02:10 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: throttle body
well mine shifts to 6g. I got some mods, but not much. I have a aftermarket tach also. so ya. Lets see, perf. distributor cap & rotor, msd coil, msd wires, ngk plugs, a/c delete frees u some, no smog or anything like it, aftermarket gears, ya i think i hit 6g
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
