Cam for L98
Old 02-06-2006, 02:06 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Cam for L98
Hey guys I am looking for a better cam for my 89 L98. So far I have checked out Comp- Xtreme Energy cams beacuse I hear they give good gains. Right now I am running 13.5 and I am trying to break a 12.9 and still be street legal. So I am thinking about a mild cam. Any info on a better cam would be helpful such as comp cams,ZZ4,LT4,EdelBrock ect...I am really trying to decide which to go with. Thanks
Old 02-13-2006, 06:31 PM
Car: ws6
Engine: ls1
Transmission: m6
Anyone out there? lol
Old 02-13-2006, 07:26 PM
91Z28-350's Avatar
Old 02-13-2006, 07:49 PM
Car: ws6
Engine: ls1
Transmission: m6
Ya I did...Wanted a recommendation.
Old 02-13-2006, 08:26 PM
stubbs's Avatar
Car: 1987 Corvette
Engine: 383 TPI
Transmission: 4+3
The ZZ9 from TPiS is a really nice cam, excellent for a street car, I went with the ZZ409 which is a little more hoped up on the intake, here's the specs for both and both are 375 dollars
ZZ-9 HydraulicRoller:
Intake Exhaust Advertised duration 282 287
Duration at .050 212 226
Gross lift .483 .520
Lobe separation 112
ZZ-409 Hyd Roller:
Adv. duration 287/287, duration @.050 226/226, Lift .520/.520. 112 LSA.
Old 02-13-2006, 10:19 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i still have a brand new in box comp cams xe282hr10
230/236 duration
510 520 lift
110 lsa
200 shipped.
2200-5800 rpm
great for tpi!
Old 02-13-2006, 11:33 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
The 212/218 cam
with .488(was it .498) and .498 lift is a great one in near stock configured TPI car.
Had a couple friends run it now from Comp
Little tweaking just makes it a nice clean puller wherever you drop the pedal.
later
Jeremy
Old 02-14-2006, 12:25 AM
91Z28-350's Avatar
3.8TransAM, That's the 08-501-8.
Stock heads? Go search. Stock intake? Got gears? Got stall?
I'd go for the XFI grinds and not look back. 08-466-8 aka 268XFI HR13 218/224 @ 0.050 .570/.565 113LSA.
Old 02-14-2006, 12:06 PM
jmiller's Avatar
Car: 87 IROC - 67 Camaro
Engine: 383 TPI - ZZ4 TPI
Transmission: 700R4 in both cars
Axle/Gears: 3.27 - 3.36 posi in both cars
I've got a TPIS ZZ9 cam in my 383 87' IROC, and a stock ZZ4 crate motor in my 67' TPI camaro. Both are MAF setups. Have absolutely no complaints with either daily drivers. Obviously the ZZ9 cam is more radical than the ZZ4 cam , but it has no downfall with TPI. I have stock torque convertors (700R4 trans) in both cars and see no need for a high stall convertor. Dead idle stomp on throttle simply turns the car sideways through both first and second gear, no bog or hesitation with either car.
Old 02-14-2006, 01:09 PM
Car: ws6
Engine: ls1
Transmission: m6
Cool. Whats a ZZ4 cam go for including labor?
Old 02-14-2006, 04:41 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
you can get them from pace parts for 200 i believe. But if you search ebay there is this one guy that has like 10 of them .. 155 plus 15 shipping. Good deal if u ask me. Mine is on the way )
Old 02-14-2006, 06:40 PM
Car: ws6
Engine: ls1
Transmission: m6
hmm not bad. Im not a big fan of ebay though.
Old 02-14-2006, 07:41 PM
Shagwell's Avatar
Car: projects.......
I agree on the suggested specs/cams...
...both are 375 dollars
but thats rediculous. Over 3 beans for a cam is nuts.
My Herbert was $220...and it's billet, not cast like some.
Old 02-14-2006, 07:52 PM
jmiller's Avatar
Pace Performance: 800-748-3791
ZZ4 Cam - Current price is $192.95 + shipping
Old 02-14-2006, 08:04 PM
91Z28-350's Avatar
Labor? I hope you're not serious.
Over $1000 total more than likely unless you find a fixed price somewhere....which may exist. That's cam, springs, shims, retainers, valve stem seals, fluids, gaskets, and a whole ton of labor @ $95/hr where I'm at.
Isn't it funny how all these cam posts turn into the perpetual ZZ4 cam stuff. Even when alternate suggestions are given, the people always want the ZZ4 as if it's ***'s gift to TPI. There were at least 3 separate threads all talking about the ZZ4 cam on the front page alone.
Old 02-14-2006, 08:57 PM
Car: ws6
Engine: ls1
Transmission: m6
Actually Comp Cams is my number one choice. It seems alot of people in here have ZZ4 cams, thats why I asked about it.
Old 04-05-2006, 04:23 AM
Blackbari's Avatar
Car: 1988 IROC
Engine: B2L
Transmission: MD8
Axle/Gears: 2.77 9 Bolt
Need Chip?
3.8TransAM, do you have to burn a new chip for a ZZ4 engine or that cam you recommended? I am asking because I really don't know. I get the impression that if you install a slightly longer duration and slightly higher lift cam than the stock hydraulic roller TPI cam with MAF, a new chip isn't really needed unless you want to take full advantage of the new cam. Is this true?
Old 04-06-2006, 12:32 AM
bonz's Avatar
Car: 89 GTA
Here is a list of mods I went with. I havent done any tuning with the computer and it runs fine. It has a awsome idle to.
Mods. GMPP Vortec heads, Comp Cams XR269HR, Crane Gold Rockers, Hooker headers, SDPC intake manifold, free flow exhaust, Air Foil, TB Bypass, K&N filter. Future mods, TPIS Runners, AFPR.
Old 04-06-2006, 04:52 AM
Blackbari's Avatar
Car: 1988 IROC
Engine: B2L
Transmission: MD8
EGR?
Hi bonz,
Do you still have an EGR valve since you have Vortec heads? If so, any trouble codes?
Old 04-06-2006, 11:31 AM
Shagwell's Avatar
I wouldn't go that big with stock heads, even ported you'd be past them.
- DANS87GTA is running 210/214 @.050, 497/502 with stock ecm/tune.
Old 04-06-2006, 03:53 PM
Car: ws6
Engine: ls1
Transmission: m6
u will have to change ur shift points as well, beacuse u will be making more power after 5K.
Old 04-06-2006, 07:13 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
how does the zz4 cam compare to a LT4 hotcam in performance and tuning etc.. are they very similar?
Old 04-06-2006, 10:21 PM
bonz's Avatar
Car: 89 GTA
Yep I removed the egr and have not had any trouble codes even after driving well over an hour straight. I also removed the smog pump to clean up the bay.
Old 04-07-2006, 07:36 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
The ZZ4 and LT4 HOT cams are quite different. The HOT cam has more duration (218/228 degrees @ .050" instead of 208/221) and I think more lift, so it'll make more upper-end power and idle a little lumpier (might need to program in a higher idle speed).
Old 04-07-2006, 03:55 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
actually you don't make much power past 5000 rpm. I have it and with a ported edlbrock intake and runners ...stock heads . I got a peak of 4900 rpm. Untunned. The heads really hold it back I think . But you will also have to have the heads modded to handle the higher lift too .
Old 04-07-2006, 05:01 PM
DodgeTech's Avatar
I'm in the same delma with my 5.7 TPI. I'm in need of a cam badly. The engine is bone stock and I'm gathering parts before i assemble and install it. I was browsing the XFI cams. I'm looking for something that will give me a nasty idle. I really want the biggest cam i can wedge in the engine WITH the stock heads. I dont plan on changing the heads anytime soon either. Any recommendations? I'm looking at these scorpion roller rockers as well. What size is the studs on these TPI 5.7s? The catolog is saying me 3/8 and 7/16. I want to go with the 1.6 size but dont know the stud size I'm going to have to get rods and valve springs as well.
Old 04-07-2006, 06:01 PM
1bdbrd's Avatar
Car: 1991 Trans Am
your not going to be able to run a very big or "nasty" cam with stock heads. you also dont have pressed in studs for your rockers. i believe you have to have the heads machined to accept 3/8 studs and then have the heads machined for bigger springs but a search on here about the heads would give you exact answers.
Old 04-07-2006, 08:30 PM
DodgeTech's Avatar
its either 3/8 or 7/16. i cant remember what i used last time i built one of these engines. you dont need to machine the heads for springs either, you just pick up a stock size pair that are stronger. i wish i could remember what i used last time i built one of these things
Old 04-08-2006, 09:51 PM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
Actually Shagwell its 214/220 @.050 come on man i thought you knew my car as good or if not better than me! and its a howards cam part # 110235-12 and it has a rought idle people think that i have an ungodly cam in it and im running stock heads that have a competition valve job ported and she runs really good but later im going to get a cam with more dur. and more lift but next for the motor is vortecs cant wait.
Jorlain
10-08-2015 01:57 AM
scottmoyer
09-07-2015 07:06 PM
Strick1
09-04-2015 07:11 AM
Formula_88AE
09-03-2015 01:47 PM
z28guy134
09-01-2015 11:50 PM
Quick Reply: Cam for L98
