compatible?
Old Feb 19, 2006 | 05:25 PM
1bad88droptop's Avatar
Car: 88 camaro drop top custom
Engine: turbod lt1
Transmission: t56
compatible?
Alright so i was lookin on jegs today and they got a great kid that im intrested in. It says its for your 88 to 95 TPI. Can i use this kit on my 86 TPI? http://www.jegs.com/webapp/wcs/store...1191&langId=-1
Old Feb 19, 2006 | 05:31 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'm guessing the only difference is the distributor. If you have a remote mount ignition coil then you could do it although stock 86s had in-cap coil. Just check under your hood to see if its been changed out. If you see 9 spark plug looking wires on the distributor cap then that kit *should* work.
Old Feb 19, 2006 | 05:50 PM
bonz's Avatar
Car: 89 GTA
The air filter in that kit is for speed density.
Old Feb 20, 2006 | 12:02 PM
Engine: turbod lt1
Transmission: t56
ok ill check for 9 wires then, but what is the speed density, i dont know much about tpi, i just got this car and trying to build it to be reliable for me to drive everyday.
Old Feb 20, 2006 | 01:16 PM
Car: 86 T/A
Engine: HSR 355
Speed density is 90-92, it measures the air through vacuum rather than using a MAF (mass air flow sensor) used from 85-89.
Old Feb 20, 2006 | 06:41 PM
Engine: turbod lt1
Transmission: t56
so y would they say it fit on 88 to 95 if speed density didnt come in until to 90. I think it should prolly work with my car, but i dont want to spend that money and it not work.
Old Feb 20, 2006 | 07:56 PM
bonz's Avatar
Car: 89 GTA
They may say it just to sell the product. But either way if you have a MAF that air filter will not work. Everything else should be the same. Dont try and use that filter if your car is MAF.
Old Feb 20, 2006 | 08:31 PM
bonz's Avatar
Car: 89 GTA
Just a follow up. I dont know why it says 88-95 TPI. TPI's last year was in 92, correct me if im wrong. It would work if your system was converted.
Mods. GMPP Vortec heads, Comp Cams XR269HR, Crane Gold Rockers, Hooker headers, SDPC intake manifold, free flow exhaust, Air Foil. Future mods, TPIS Runners, AFPR
tmellott89
Oct 14, 2015 02:06 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Formula_88AE
Sep 3, 2015 01:47 PM
