I'm swapping in a TPI 350 in my 89 Camaro 305 TBI. The 350 will make over 300 HP and about 400 ft lbs of Torque. I haven't cranked it yet, but have been reading about throttle bodies. Should I stay with the stock 48mm. or go larger. Would jumping from 48mm to 58mm be too much?? Is the difference even worth the 300 bucks?
stock one will work just fine. (not worth the $300 to me)
GuitarJunki17
close
- Join DateMar 2005
- LocationHamilton
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1990 IROCZ Camaro
- Engine350 4bbl, 200cc Heads, 270hr Cam
- Transmission700R4 w/ Trans-Go shift kit.
- Axle/GearsGM 10 bolt Posi
- Liked:0 Times in 0 Posts
Quote:
Agreed, at that point, there are worse restrictions than the throttle body that should be addressed first.Originally Posted by Elephantismo
Most of what i have seen says to wait till >400hp Member
Yea, I agree. There are many articles, explaining this. I've heard that the stock Throttle body is good up to about 500+ hp. If anything I would just port it maybe alittle along with the manifold, plenum, and runners. You'd be supprised of the great effects of porting, its free too !!! You will also gain a few usable rpm's up top.
GuitarJunki17
close
- Join DateMar 2005
- LocationHamilton
Quote:
qft, porting will help out some.Originally Posted by cheese_kake
Yea, I agree. There are many articles, explaining this. I've heard that the stock Throttle body is good up to about 500+ hp. If anything I would just port it maybe alittle along with the manifold, plenum, and runners. You'd be supprised of the great effects of porting, its free too !!! You will also gain a few usable rpm's up top. Member
Excuse my lack of knowledge but what does qft stand for ??
LOL I see, cool. I see alot of new acronyms on here. Yea porting is an excellent source of power in stock intakes. I just started the giant task of gasket match porting my heads, pain in the *** but deffinately rewarding.
Awesome, thanks for the info guys- I have polished the throttle body inside. You sware it was dipped in chrome! I have ported and polished the stock intake manifold. All 8 ports are smooth as a babie's butt. Heads are Aftermarket and have been polished also, and slightly ported. I have knocked down the EGR wall in the plenum, and was looking for other ideas. Thanks again-
Quote:
do a search on porting the plenum, you will find good posts & picsOriginally Posted by techno101
