valve steam seals tutorials
Old Aug 2, 2006 | 06:47 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
Ive searched on this site, and although there are many instructions on changing valve seals, are there any instructions with pictures? I need to change them on my 305 TPI. Pictures would help make it a lot easier. Also does the Chilton or Haynes repair manual for these cars include instructions or pics of changing the valve seals?. Thanks guys. Other referrals would also work. Thanks again.
Old Aug 2, 2006 | 06:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I'm doing a set this weekend, I could take some pictures then.
It's pretty straightfoward though, once you start doing it and seeing it all in front of you the descriptions make sense.
Old Aug 2, 2006 | 07:24 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Man. Much appreciated. That would great if you could do that. Doesnt have to be elaborate. A few pictures will do. Thanks again. By the way, what kind are you installing?....I just need some good replacements, not too expensive for a 87 305 TPI. Any suggestions?.
Old Aug 2, 2006 | 07:43 PM
92comaro/conver's Avatar
Car: 92 comaro-rs
Engine: 3.1liter/supercharged350 comingsoon
Transmission: 700R4 trans.
chiltons or haynes repair manuals will show you step by step on how to do it pretty simple
Old Aug 2, 2006 | 07:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Fel-Pro SS72527
They're listed as intake valve seals, but get two sets and use them on the exhaust, too.
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Get a pic of your car(s?) too I'm curious what you drive.
Old Aug 2, 2006 | 07:51 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Nah, too ugly for pictures.
Old Aug 2, 2006 | 07:53 PM
Car: 92 comaro-rs
get stock replacment and grind valve seals to valves for proper seating on valve
Old Aug 2, 2006 | 08:13 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Grind???...Im not grinding s***. That usually means you either got the wrong part or your doing something wrong. Theres got to be a replacement that doent involve grinding or modifictaion of any sort.
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There'll be no grinding involved, don't worry.
Old Aug 4, 2006 | 01:16 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I just did a set on my car along with valve springs. The biggest thing to remember that your Haynes manual won't illustrate is that the umbrella's and retainers go on and are compressed before the seals go onto the stems, after that the locks go on and you release the spring. I got the clamp style compressor rental from Auto Zone and it made it a breeze, just ran compressed air into the cylinders, clamped old springs (had to tap a few of them to get the retainers off the locks) pull the old and install the new. This was for the O ring stem seals, the intake style seals are the same but they go on before everything, mine were newer so I left those alone. Now that these are on the car doesn't smoke a BIT on startup.
Old Aug 4, 2006 | 01:22 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I won't be having any umbrellas in the pictures. I use positive seals on all cylinders. I suppose they're similar enough, though.
Old Aug 4, 2006 | 03:31 AM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
If Im going to have my cylinder heads off to change the gaskets, would it make the job a little easier? Im figuring I wont be needing the air compressor adapters if the cylinder heads are off. Would I still be needing the valve spring compressor??
Old Aug 4, 2006 | 05:14 AM
jethawk's Avatar
Car: 1991 Firebird Formula WS6
Engine: LB9
Axle/Gears: 3.42's
yes you'll still need a valve spring compressor... most autoparts stores that rent tools will have 2 versions... an on the block one and a off the block one.... either one will work off the block..... but the off the block one wont work with the heads on the block!
jethawk's Avatar
Engine: LB9
Axle/Gears: 3.42's
** Edit.. whoops double post!**
Old Aug 4, 2006 | 10:03 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yeah, do it with the heads off for sure.
Old Aug 6, 2006 | 08:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ok, I didn't know what to take pictures of really, so here's a few. Actually doing the seals only takes a minute or two per cylinder. The fun and frustration comes from getting at them. As with everything else under the hood, a little patience goes a long way.
This is what you get in the intake valve seal kit. Eight positive seals, 8 o-rings and the little plastic installation tool.
Depend on which type of valve spring compressor you use, you don't have to remove the rocker to do the valve seals, just back the nut off until you can turn it out of the way. If you count the turns and you're careful not to disturb the nut, you don't even have to cold lash the valves again afterwards.
This is the type of compressor I like to use. Any type of on-the-head compressor will work, though. If you're doing it with the heads off, I like the giant C-clamp type best.
This is what you'll see when you take the valvespring off an intake valve. Exhaust valves are similar, but don't have the positive seal at the bottom. You can see the offensive O ring in the second groove. This is also pretty much what they'll look like after you've put the new seals on, just a little cleaner and shinier.
As soon as you touch it, you'll know why they leak.
This is what the valve stem and guide look like with the seals removed. Both the intake and exhaust valve guides are machined this way, so they'll both take positive seals with no problems.
Old Aug 7, 2006 | 12:11 AM
Sonix's Avatar
Car: 1982 Trans-Am
-what did you use to hold the valve up?
-did you put the exhaust rotators and umbrellas back on? Do you need umbrellas with positive valve seals? And did you use the o-rings as well?
-would it be worth removing the rotators and shimming the spring up, since you're there?
Old Aug 7, 2006 | 12:47 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I use an air holder to keep the valves up. If you have access to compressed air, I find it more convenient than the rope trick.
I didn't do anything to the springs and retainers at all, they stayed in the compressor the whole time.
If it was a performance engine where I was worried about valvetrain weight, or if I cared enough, then the rotators would go. It just didn't matter to me this time, though.
I use both the positive seals and the O rings. Not really any reason not to. Stock, there are no umbrellas on the exhaust valves, only the O rings. I don't think there'd even be enough room under there for positive seals and umbrellas together.
Old Aug 7, 2006 | 10:32 AM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Thanks a lot Apeiron! This really helps. What kit did you use for this, and where di yiou purchase it. Also, do I just buy (2) of these kits, and use one for intake, and one for exhaust??. Would it be a good idea to change the retainers on the springs? I too am like you, and dont care much for valvetrain weight.
Old Aug 7, 2006 | 12:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The kit is in the first picture, Fel Pro SS 72527. You can buy it at any parts store that sells Fel Pro gaskets. One kit does 8 valves, so buy two to do both the intake and the exhaust.
If you want to use umbrellas on the exhaust instead of the positive seals, you can buy a set of SS 72877 for the exhaust and SS 72527 for the intakes.
You might also want or need to replace the valvecover gaskets, too. Get the counterperson to look them up by application.
All these part numbers are for stock heads, by the way. Older heads, or aftermarket heads might not be machined the same.
I didn't change any of the valvetrain parts on my car, it's not a performance engine. If I was putting a hotter cam in or something, then I'd change everything.
Old Mar 1, 2007 | 07:35 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
OK Apeiron,i just did the felpro umbrella seals on my 3rd gen,and its stilll smoking.it doesn't smoke with the car running at idle but when i rev it wow, here comes the smoke.i just found this thread & read through it.i didn't use the o-ring seals on either the int. or exh. sides i thought that you just used your choice umbrella or o-ring.i guess i need to pull the valve covers off &try again huh?i had the same problem prior to the seal replacement,and at first i thought that there was just still some oil in the heads that needed to burn off.or is that hopefully just what i need to do? i haven't even driven this car yet just been working on it on weekends.do i need to put the pos. seals on the valve stems? also, i am using the same valve spring comp. &compressed air
Old Apr 25, 2007 | 11:28 AM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
Re: valve steam seals tutorials
I just got done replacing my valve springs and seals, and this thread helped me out a lot.
I didn't use an air compressor or rope to keep the valves up. I found by rotating the crank to get TDC on the cylinder I was working on the valves wouldn't fall into the motor. Don't forget to move it for every cylinder, as I almost lost 2 valves! The valve seals were able to hold it up for reinstalling the springs.
Just my
Old Apr 25, 2007 | 12:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The amount of pain and suffering involved in retrieving a dropped valve makes it not worth the chance.
Old Apr 25, 2007 | 01:46 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
what is the plastic installation tool for. just to push the positive seal down? normally I just put some engine lube on the valve stem and it slides fairly easy.
Old Apr 25, 2007 | 01:49 PM
trumps2000's Avatar
Car: 1985 Z28
Defintely risky, I almost freaked when I saw it pushed in. My headers prevent me froming getting to some of the spark plugs even to change them, let alone the compressed air adapter.
The reason for the plastic tool is to keep the valve stem grooves from messing up the seal.
Last edited by trumps2000; Apr 25, 2007 at 01:52 PM. Reason: Automerged Doublepost
Old Apr 28, 2007 | 08:25 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
Funny you should mention that, I replaced my springs last week and did EXACTLY that. I didn't feel like yanking those plugs out, they're such a pain in the ***. I marked the balancer at 90 degree increments from the timing mark, went TDC on #1, then rotated the crank the appropriate number of quarter-turns to do each cylinder. I just made sure to do the intake valve first, in case I had the wrong cylinder. The intake is coming off next, I would've (hopefully) been able to fish any dropped intake valves back into place through the open ports. Well that was my theory, I didn't need to test it.
#8 was by far the worst for me. The AIR line from the converter was in the way, as was the HVAC crap on the firewall. I wound up using a lever-type compressor to get the old springs off, then the screw-type to put the new ones in. Worked like a charm.
As for the valve seals, I just pushed them on with the drive end of an old socket.
Bubbajones_ya
Jul 6, 2024 08:32 PM
355tpipickup
Sep 13, 2015 11:35 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
tgp1990
Sep 4, 2015 06:24 AM
