FI to Carb - Do I Need The Computer
Old Aug 29, 2006 | 11:05 PM
klumb15's Avatar
hey guys, if I'm swapping out my FI for a carberated setup, is there any reason to keep the stock wiring harness and computer? its an 86 iroc orignally equipped with a 305 TPI.
My fans are all hardwired, I would be getting a new distributor, and thats all I can think of that runs off the computer. All i need for a carbed motor is the starter hooked up to the ignition correct?
Old Aug 30, 2006 | 06:53 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
sound like a GO to me
Old Aug 30, 2006 | 09:40 PM
klumb15's Avatar
thats what I figured, i just might've thought I was missing something...
but another quick question, for a distributor, anything that is vacuum advanced will work right? i'm looking at the MSD pro billet w/vacuum adavance, will that work? also i want the RPM airgap intake, i believe there are only 2 available, one for vortecs and one for everything else, correct? I have aluminum L98 heads, the one that says not for 87-later cast iron heads..right?
Old Aug 30, 2006 | 10:16 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
your going to need the 87 and earlier style intake(correct). and yes the Msd distributor is great for your carb motor.now ive got a question for you.
what are your plans for this motor, what size carb are you going with. if i may ask. just curious
Old Aug 31, 2006 | 08:38 AM
klumb15's Avatar
proform or holley 750 double pumper was what I had in mind, and thats what was recommended by a member on here...it'll be about 400 horsepower, so that should work
Old Aug 31, 2006 | 08:42 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Check out my sig for my combo.
I went with the ProBillit without vaccum advance. I am also running the RPM airgap with a comp 282hr cam.
Old Aug 31, 2006 | 08:43 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Sorry forgot to add my sig!!
Old Aug 31, 2006 | 08:49 AM
klumb15's Avatar
very similar setups hey...your heads flow a bit more than mine, and you have a bit more cam, but not much...i see your selling your carb, whats going to replace it?
Old Aug 31, 2006 | 08:54 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
We P&P the heads and tried some new angles on the valves. I also milled them to 60cc to boost compression to 10.3 to 1. We also worked the intake to match the heads.
I have a Holley 3310 750vs that I have raced in the past I am using. I ended up with both carbs and already have the holley dialed in. Plus the holley has notch floats, jet extensions, rear metering plate and quickfuel adjustable secondaries.
I got the Demon from a friend that bought it new from summit. His motor went south within 20 miles with the carb on it. Plus im in need of some DOT tires or slicks. I cant hook up with the new setup!!!!
Old Aug 31, 2006 | 09:15 AM
klumb15's Avatar
yea i was gonna say, you should be in low 12 range...with a carb I should be doing what your doing with decent tires
are there any advantages of going with vacuum secondaries over a double pumper?
Old Aug 31, 2006 | 10:08 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Well it is a little easier at the gas pumps. They also work ok with a auto trans.
If it is going to be a track only car, I would say go with a Holley HP carb. If it is going to street strip, you can go with VS or DP.
I will eventually change over to a HP. It should pick my car up by a couple of tenths.
Oh yeah, The 12.83 with 1.84 60ft times was at 92* high humidity, crappy track conditions, and spinning for 10-12 feet off the line.
I can make you a great deal on the carb if you are interested. Pics are at my cardomain site. car pictures and photos at CarDomain.com
Old Aug 31, 2006 | 11:36 AM
klumb15's Avatar
well i just found out that a kid that lives near by wants my HSR setup, and he has a nice carb setup, I"m going to see what he has, and maybe we'll work out a trade...
that carb looks nice, as much as I would like to buy it, i have to get rid of my stealth ram setup first..
Old Aug 31, 2006 | 01:30 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I know how that is. I really need better tires, but need to sell the carb first!lol.
If things fall through with your neighbor, pm me if you want to talk about the carb. Im negotiable in price and would consider trades.
Good luck with the swap, I started with TBI then to TPI, then to carb!
Old Aug 31, 2006 | 02:17 PM
klumb15's Avatar
i went from TPI to HSR, now to a carb...we're on the same path.. i'll pm you if i decide to buy that carb off ya..thanks
Old Sep 4, 2006 | 11:18 AM
Pat Hall's Avatar
In my experience I have to agree that a vacuum secondary Holley works best with an auto trans. My brother tried running a 650 double pumper with a TH350 trans, and it bogs going into the secondaries no matter what we tried. However a car with a manual trans works beautiful with a mechanical secondary double pumper carb. I'm running a 650 DP with a muncie 4 speed in my 69 camaro, and it screams! The MSD pro billet HEI with an adjustable vacuum advance would be a really sweet distributor to run with your setup.
Old Sep 4, 2006 | 03:40 PM
84t/a5181's Avatar
tpi to carb?
Hey Klumb? just for giggles what are U going to do w/all your old tpi parts?
Old Sep 4, 2006 | 06:12 PM
klumb15's Avatar
i have a complete HSR setup...and i'm selling it if your interested
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
customblackbird
Oct 1, 2015 04:30 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
