Which cam of these two (LPE) or (GMHOT)?
Old Sep 17, 2006 | 12:15 PM
smithtc's Avatar
GM Hot Cam 218/228 .525, .525
LPE 219 with .560, .560 and I beleive 219/219 duration at 0.050.
Whats better for a daily driver with 305, L98 aluminum heads, ported plenum, Accel Runners & intake, 5-speed, and 3.45 gears?
Not sure which would make better power or have better manners. Anyone?
Edit:
Oh, and 1-5/8 headers SLP shorties into exhaust TBD.
Would like to use Hooker Headers long tube...anyone up for a trade?
Old Sep 17, 2006 | 01:52 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you're keeping the 305, then the LPE 219 is a more docile cam. The HOT cam is better for a 350. Be prepared to have a custom computer tune done with either cam.
Old Sep 17, 2006 | 03:41 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
LPE 219 cam was designed for a 350 ci plus small block with a Super Ram intake....
Old Sep 17, 2006 | 06:10 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
LPE219 cam would be better for your engine since you have the L98 alumnium heads with the high flow exhuasy ports
Old Sep 17, 2006 | 07:49 PM
Kevin91Z's Avatar
Yeah, 15 years ago it was the hot setup. Now, there are more than a dozen cams that will beat it in every department.
(It also was made for the L98 Corvette heads, as well as the SuperRam. My statement above still applies.)
Old Sep 19, 2006 | 12:27 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
LPE219 is more docile and will work good.
Old Sep 21, 2006 | 04:04 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
The LPE cam was designed around Lingenfelters extensively ported Corvette heads. The cam is a single pattern which works best with heads that have an intake/exhaust ratio of 75% and above. The exhaust ports on those heads are weak out of the box. If you could at least have them pocket ported, it would do wonders.
Bottom line - run a dual pattern cam (more exhaust duration) with stock unported heads.
index
Old Sep 21, 2006 | 05:04 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
I'm running a LT4 hotcam in my 305 TPI with aluminum L98 heads.. was very aggressive until I got some proper prom tuning done, very good combination now. check my virtual garage for mods and videos.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
