TPI engine supposedly makes 510HP ;)
Old Nov 3, 2006 | 10:40 AM
Archaea's Avatar
eBay Motors: NEW 383 STROKER Chevy Crate TPI CANDY RED POWDER COAT (item 220043707316 end time Nov-09-06 09:48:35 PST)
discuss
Old Nov 3, 2006 | 12:06 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
I don't think it is red enough! I think there should be more red paint!
Old Nov 3, 2006 | 12:25 PM
turbochargedrs's Avatar
Car: Fire Red 89 RS
Engine: 2.8L :(
Transmission: 700r4 auto
thats the worst power
If you could make a 383 have 510 cheap enough to sell it with no reserve every guy on here with a 350 would do that in a heart beat. I think its crap, maybe pushing 510 with a nice psi boost or good shot of nos.
Old Nov 3, 2006 | 01:33 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Looks kind of nice maybe with a little less red and some polished aluminum it would look really good, purple injectors would have to go though lol.
Old Nov 3, 2006 | 01:41 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Wow
And not even an aftermarket base or runners, he must make that 500hp at 4100rpm
Last edited by 1991CamaroRslow; Nov 3, 2006 at 01:41 PM. Reason: Automerged Doublepost
Old Nov 3, 2006 | 03:01 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
That thing should be taken out back and be used as target practice
Old Nov 3, 2006 | 04:40 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
yeah I seen that the other day.....Way too much red for me.
Hard to see getting that much hp from what looks like a stock runners and plenum....maybe even a stock intake. I think it would have a hard time breathing.
Yeah and purple injectors.......I think that would make the HP #'s alot lower! LOL!!
Old Nov 3, 2006 | 05:40 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
..not with those runners and intake system. The color alone is going to cost the moter 25hp. Hehehehe.
Old Nov 4, 2006 | 02:07 AM
BadSS's Avatar
I don’t know,,, the timing cover not being powder coated red just plain sucks,, so I’m going to have to pass on this one.
Old Nov 4, 2006 | 12:27 PM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
I asked and they sent Dyno Sheet.
Old Nov 4, 2006 | 01:23 PM
Car: 1989 GTA
Engine: 369 TPI
They didn't send the 515hp dyno sheet.
Old Nov 4, 2006 | 02:25 PM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
I busted my gut over the HAND SELECTED CAMSHAFT. This seller is smoking crack if he think he can make that kind of power with stock runners.
I dont think its possible.
Old Nov 6, 2006 | 04:38 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Originally Posted by 1991CamaroRslow
Wow
that's like 650 ft lbs of torque!! The sad part is it has 9 bids on it
Old Nov 6, 2006 | 05:07 PM
Guest
Guest
Posts: n/a
HP peak at 5500 through a stock intake?
Old Nov 6, 2006 | 07:31 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Looks sketchy all around, and the paint just looks like he doused each part in gloss candy apple red spraypaint. Like im seriously wondering if that AC clutch is stuck to the actual pulley lol.
Old Nov 6, 2006 | 09:01 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
He used a 230 intake on a stock TPI
That engine has not been ran. Look at the exhaust ports, clean as a whistle. I wonder what that hand selected cam is.
Old Nov 7, 2006 | 12:39 PM
Abubaca's Avatar
When I did my cam swap I hand selected my L98 cam, took it out, and put it on a shelf.
..sorry.
Old Nov 8, 2006 | 01:55 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Attachment 128518
Theres no way thats a stock tpi intake dyno. Look @ the curve!
Complete bs... sucks for the winning bidder.
Old Nov 8, 2006 | 04:53 PM
Drac0nic's Avatar
Yeah, that TQ curve is definitely for an engine equipped with a short length runner setup like an LT-1 intake. he's got WAY too much TQ over too high of the power band for a long tube style intake even if it's got a ton of aftermarket parts on it. I'd think that there'd be real steep drop off of TQ at low RPM even with the best TPI parts if he was running 230CC intake runner heads, can you say lazy ports?
Old Nov 9, 2006 | 05:09 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
Wait a minute! Doesn't that dyno sheet looks like it was made with that desktop dyno program? Definitely BS....
Old Nov 9, 2006 | 05:32 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
You should e-mail them back and say that they must have sent the wrong dyno slip because its doesnt seem to show 510hp.
Old Nov 9, 2006 | 10:11 PM
ht4100's Avatar
Car: 86 Z28, 86 Seville, 98 Isuzu Rodeo
Engine: 383, HT4100, & 3.2 V6
Transmission: World Class T-5
Axle/Gears: G92 3.23
Looks like something doesn't add up
Old Nov 9, 2006 | 10:17 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
Looks like another case of the dreaded "MOUTH DYNO"......lol
The_Phoenix
Sep 3, 2015 10:56 PM
Linson
Aug 21, 2015 02:12 PM
st.evel07
Aug 13, 2015 06:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
novaderrik
Aug 10, 2015 12:44 PM
