middle 2 throttle body plate threads stripped !
Old Dec 2, 2006 | 11:02 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Will this be an issue if i just use the outside corner bolts of the throttle body plate to bolt it down with??
Its all attached but i forgot to use anti seize on the bolts
yea i got too excited and forgot about that .... damn threads!!
anyhow so the corner bolts are all in and i put some black rtv sealant on both sides of the gasket .... or face the inevitable and drill them out / heli coil
I wont do the same mistake when bolting down that tps !!
was hoping its not such a big deal... anyone with some insight would be greatly appreciated
Old Dec 2, 2006 | 11:37 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
You might have issues with vacuum leaks. Get a vacuum gauge and attach it to the manifold and see how much vacuum you are pulling. I think 18psi or hg/m or whatever the reading is will suffice.
Old Dec 3, 2006 | 07:31 PM
onfire's Avatar
Car: 88 Formula 350
Thanks guitar,
Im goin to try to get some shorter bolts to see if that'll do the trick...
Last thing I need is a problem with vacuum.
Rabi C
Old Dec 3, 2006 | 07:43 PM
Just so im clear, this is the throttle body plate that has "Tuned Port Injection" on it right? Now that I think about it I'm actually not sure if that would cause an issue with vacuum. Coolant might flow through that section of the throttle body instead, I'm not sure, I hope someone can back me up on this. If that is the case, and you cant fix the bolts, just do a throttle body coolant bypass, and you'll be alright.
Old Dec 4, 2006 | 08:31 AM
onfire's Avatar
Car: 88 Formula 350
Yes
It is the "tune port injection" plate. I cut the coolant passages and bypassed it. So it would not see any coolant through that area. Just wanted to make sure that it wouldn't be a problem if left without the 2 middle bolts.
Thanks again Guitar!
Rabi C.
Old Dec 4, 2006 | 10:04 AM
Vader's Avatar
It might seem a little "funky" but you can re-tap the holes for 10-32 screws.
Got anti-seize?
Old Dec 4, 2006 | 03:25 PM
jack harrison's Avatar
Car: 1987 pontiac trans-am
Engine: 350 tpi
Axle/Gears: 3;73 with eaton lsd
do you mean the plate ON TOP of the throttle body? i wasnt aware that it would make a differance in vacum if that top plate wasnt held down? i may be wrong.
Old Dec 4, 2006 | 06:31 PM
Yeah see, I wasnt sure either, but there is a gasket under there, so I figured something might leak.
Old Dec 9, 2006 | 01:28 AM
onfire's Avatar
Car: 88 Formula 350
Yes
It is the plate on the top of the throttle body that usualy says Tune Port Injection. My whole concern was that I didnt want to loose vacuum. Does anyone know if there is an actual torque setting for these bolts or just hand tight??
Thanks,
Rabi C>
Old Dec 9, 2006 | 02:15 PM
Just snug, like 15-20ft lbs or whatever the torque for "snug" is, you dont want to over do it, or else...well you already know what happens =D
Old Dec 10, 2006 | 08:26 PM
onfire's Avatar
Car: 88 Formula 350
Thanks everyone for your help!
I checked the threads for the tps sensor and they look horrid so I guess I'll be a drilling ! Might as well since I'm at it.
I got the throttle body from one of those guys on ebay that took my old throttle body and swaped it out for a 52mm. Must have been my luck since I was trying to save some money. This guy charged me $167.40 for it. Not too bad of a deal if there was no other issues with it.
I appreciate everyone's input.
Rabi C>
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
