lubing injector O rings?
Old Oct 15, 2000 | 06:46 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
While installing the injectors we lubed them w/ motor oil to ease installing them.Every injector has a vac. leak.When I went back to parts they informed me that they should be installed dry cause they expand when the get wet by gas and the oil would prevent this and could do damage to the O rings.So when I replace the O rings should I do them dry?
86 IROC mods:T.E.S.,Flowmaster muffler
T.P.I.S. airfoil,ported plenum,March
pulleys,Accel 8.8wires,supercoil,ign.mod.
RAM AIR induction,gutted MAF,
B&M shift kit,3.73 rear gears,Accel afpr,Hypertech stage 2 chip,Random Tech.cat.,Lakewood lower control arms,Lakewood adj.panhard rod
"The more I learn about women,the more
time & money I spend on my IROC"
Old Oct 15, 2000 | 08:55 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I've heard people use white grease so they come back out easier. I installed mine dry however, I'll just replace them if I tear one on removal. Which I'll probably be doing this week.
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Oct 15, 2000 | 10:13 AM
RP1987GTA's Avatar
who's orings did you use?I've used GM kits and always lubed with motor oil and have never had a problem.
87GTA,350,Auto,MAF screens removed,195 thermostat,cold start injector UNPLUGED,K&N,modified air intake,ADSchip,3:73s,3inch cat back Flowmaster single outlet,TPS.54,Bosch Plat plugs,base timing 6BTDC,22 MPG and runs like a bear,Bilstiens in the rear....,don't let yer meat loaf
Old Oct 15, 2000 | 05:35 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Bill you didn't lube your "O" ring enough Still having problems? I think Kat has just about gave up
89 GTA 350 TPI(L-98)Fiberglass "Daytona Turbo" hood K&N filter air foil Stage 2 Fastchip B&M Stage 2 shift kit Flowtech shorty headers SLP 3'' exhaust Cams HI-6S igntion with PS-91 coil MacEwen white gauges overlay's SLP rear sway bar Koni's all around and one kick *** stereo!
Rice....it's whats for dinner
You can see a pic of it by going here:
http://www.hometown.aol.com/clarkemustgonow
Old Oct 15, 2000 | 06:41 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yes, you need to lube them, but you also need to use "fuel injector o-rings" like mentioned before. If you don' lube them, then you run the risk of tearing the o-rings.
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
Old Oct 15, 2000 | 07:04 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
I used fuel injector O rings lubed w/ 5w30 motor oil
Old Oct 15, 2000 | 11:35 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
hey Tony I didnt give up yet man.. But I di say I hate TPI! =)
Kat
90 RS 305 TBI A4
Dumb ***/**** poor/orginating memeber of the infamous NE Crew
Time to see, believe this in me,This pain that i feel deep inside
Old Oct 16, 2000 | 07:09 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
THNX Kat,
We'll get her this Thurs!!!!
BD3
B&M shift kit,3.73 rear gears,Accel afpr,Hypertech stage 2 chip,Random Tech.cat.,Lakewood lower control arms,Lakewood adj.panhard rod,mac subframe connectors
Old Oct 16, 2000 | 07:52 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I rubbed a little motor oil on my o rings before I installed them, and I don't have any leaks at all. My o rings came with the new injectors.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
64Chief
Sep 12, 2015 08:05 AM
Randomtask2
Sep 7, 2015 05:06 PM
BOOT77
Sep 5, 2015 03:55 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
