code 42 and my headers glow red within 2 min of start-up
Car: 87 GTA / 87 IROC-Z
Engine: 350 TPI / 350 TPI
Transmission: 700R4 / 700R4
Axle/Gears: Stock
hey guys i have solved all my running problems with 1 now new exeption code 42! how can i fix this 1. i just also noticed today that my headers are also glowed red when i had the car running wtf? anyone know please and thanks
87_gta
87_gta
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: code 42 and my headers glow red within 2 min of start-up
not sure about the code 42 (Electronic Spark Timing (EST)) are all your wires connected? and i think that misfiring causes headers to glow red. sorry i couldn't be more of a help
Axle/Gears: Stock
all my wires are connected i have gona over everything, and all connections are good, doesnt sound like its missfireing. could this be ignition control module? when i went to start the car i had to keep on the gas for a bit but i only been doing this since code 42 showed up
Car: 89 trans am gta
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
hi 87_gta if you have cats check them if they break and block your exuast your headers will glow red also does it rev freely above 2-3000 rpm engine will usely strugle to rev if cat is broke hope it helps
Car: 91 Z28
Engine: l98 5.7 TPI
Transmission: 700R4,2600TCI stall,Trans Go
Axle/Gears: 3:73
I had the same problem on a regal. The cat convertes were cloged. I cut them out problem solved.
Axle/Gears: Stock
it will idle pretty well over 1500 to 3000 but thats when the headers start to glow, i have a dual exhaust on the car with 2 cats could both get clogged like that?!? it even gives my trouble starting still, could all this be related to code 42?
Car: 1986 IROC
Engine: 355" TPI
with code 42 showing you are most likely not getting any advance above the base.
Axle/Gears: Stock
i have fuel, i have checked that a few times now. i havent touched the timing at all. this code showed up after i had all the spark plugs out and and was turning the motor over to clean out my cylinders
Axle/Gears: Stock
did a little observation of the car while idling and the headers dont turn red while its idleing. I had the car running for 5 min no red glow, all the other times i was on the gas. i was told by some people i know that headers glowing is a sign of running lean. also when im in drive and i give it gas it doesnt want to go, like it has no ***** what so ever. none of this happened before code 42 showed up. my repair manual says for code 42: poor electrical connction, open or short in circuit; defective ignition module; defective ecm. i have gone over all the electrical connections and their alll tight. im not totally sure how to check for an open or short in circuit. i do want to check my ignition module but according to the repair manual i have to take my distributor out ??wtf? and i kno my ecm is working properly cuz i unplug other sensors and it picks it up. i do want to check my igniton module but do i really have to take the distributor out of the car or can i just take the cap off to get at it?
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Is your E.S.T. where mine used to be located. I used to have a 165 ECM with MAF and my EST was located directly behind the power booster on the wirewall. It is a box about 3 inches by 3 inches in Diameter. If you are running a 730 S/D ecm which is evident by a Map Sensor, your E.S.T. would be in your Distrib Cap and controlled through your ECM.
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I thought for the 165 ( well my 89 ) that teh EST is IN the dizzy . It's the plug you pull out when timeign the car ?( brown tan wire)
Axle/Gears: Stock
Well i have 110% found my problem my ECM is done. swapped the 1 from my iroc into my GTA and everything is now perfect accelerates good no glowing headers starts right away. now i just have to find a new ECM
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Hey guys I am having code 42 problems myself. Poor power, I have spark to all 8 but not ruuning on all 8? I'm going to get my ingnition control module check out now at an auto part store. any advice?
Axle/Gears: Stock
mae sure they test it a few times until its nice and hot that way you know its being tested under running conditions. i have heard of some people that have tested them and on the 3rd try it tested bad, never know i guess. for me it was my ecm. if not the control module also test the pick-up coil and make sure its not shorting to ground. if it is i would replace that, about 20 bucks at parts store.
1992rs/ss
16
01-28-2016 09:58 PM
hectre13
09-08-2015 03:38 PM
mdtoren
08-16-2015 05:45 PM
