how can I increase my throttle response
Old Nov 2, 2000 | 12:22 PM
chris1roc's Avatar
How can I increase my throttle response. I have 108,000 miles and she's getting sluggish. There's about a 3 or 4 second pause from when I lay the pedal to the floor and from when she actually goes. What about a new fuel pump, filter and regulator? Would that help?
Old Nov 2, 2000 | 02:12 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
chk your timing chain. I 'm not kidding my IROC had 98k on it when i bought it and the chain wasa so loose i had 10+ deg of play in my timing before the rotor would move. Try it. Take your cap off, spin the motor over to TDC by hand then watch or have someone else watch and count the degrees before the rotor moves. WOW the difference was outstanding. Good luck .
'89 SHAGGY IROC
L98 7r4, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc.
so much to do , so little money
Old Nov 2, 2000 | 03:14 PM
rondubbs's Avatar
increase your tps from .54 to .62vdc
Old Nov 2, 2000 | 03:30 PM
chris1roc's Avatar
what's tps? Can you explain better?
chris
Old Nov 2, 2000 | 03:54 PM
rondubbs's Avatar
sorry,, tps = throttle positon switch, located on the left side of the throttle body.. by increasing the voltage, you are opening the throttle body blades more.. by doing this it will give you better throttle resonse when you smash down the gas pedal. to increase it,, just loosen the screws on it and move it up/down.. use a digital voltage meter to make sure you dont go above .62 vdc. read this--> https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
Old Nov 2, 2000 | 08:06 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I found increasing the fuel pressure (not too much though) also helps with throttle response. You need to buy an adjustable fuel pressure regulator so you can adjust the fuel pressure. On many cars, the fuel pressure is on the low side and this help promote better atomization and bit more power on WOT.
But don't go crazy with the fuel pressure. Too much and you'll run too rich at WOT and kill performance.
Old Nov 3, 2000 | 06:43 AM
blak92!'s Avatar
Timing and check for vacuum leaks.
Old Nov 9, 2000 | 06:07 PM
BlueBottleJunky's Avatar
buy a holley carb and an edelbrock intake.......NOT....LMFAO
DiabloWS6
20
Dec 11, 2015 04:12 PM
BWilcox
Sep 20, 2015 12:19 PM
banksGTA
Sep 13, 2015 11:56 AM
Randomtask2
Sep 7, 2015 05:06 PM
rsrookie
Sep 5, 2015 07:08 PM
