Why is car running so rich
Old Nov 18, 2000 | 06:58 AM
Larrys T/A's Avatar
Car: 1988 Pontiac Trans Am
Hey i have a 1987 Trans Am 350tpi. With the screw on the AFPR all the way out the car is running to rich. You can't stand behind the car before the fumes run you out. I Have the stock 19lbs injectors. What do you think the prablem is. Thanks
  • 1987 T/A 350tpi, 5speed,SLP Headers,Stock 1995 Z28 Muffler, Gutted Cat,Compucam 2030 429 452 & 204 214,TbBypass,Ported Plenum,AFPR, SLP LCA,SFC. 13.86@96.4 with 1.96 60ft
Old Nov 18, 2000 | 11:27 AM
BadSS's Avatar
Need more info. When did it start running rich? Did you change or add anything? Will the fuel pressure change when you adjust it? What is the pressure reading with and with out vacuum?
Old Nov 18, 2000 | 01:54 PM
rondubbs's Avatar
are you getting any codes?
you may need a new o2 sensor.
Old Nov 19, 2000 | 09:08 PM
Larrys T/A's Avatar
It started running rich as soon as i put the 350 engine in. Also when i change the pressure it goes up like it is suppose. With the vacuum on it reads 36psi with it off it reads 46psi. I'am getting code 24 and 42 which are speed sensor and ignition spark control. I know it confusing. Please help
Old Nov 19, 2000 | 09:27 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I'm not sure what your problem is, but I did the same thing with the same results. You probably should go to a 350 chip. I went to a chip burner guy and change the settings to lean it down after I melted two cats.
Don>>>
Chronologically challenged. But still alive!
92 CAMARO RS
305 TBI 5/spd
'69 camaro
BB/Lenco
1050 dominators
8.97-150+
Pump gas/no drugs
Old Nov 20, 2000 | 03:16 PM
Larrys T/A's Avatar
Thanks DynoDon. I just put a post on prom burning.
Old Nov 21, 2000 | 02:24 AM
F22Raptor's Avatar
I don't mean to sound like a ***** Larry, but it seams to me that you are running a little slow in the 1/4. Your MPH should be a little higher, at least 2 more MPH. I'm sure the 305 chip has something to do with this as well as your too rich condition, although I though the 305 chip would make you run lean instead of rich. Oh well!
Rick
'88 GTA 350
Headers, catback, free mods, Xtreme energy cam, and intake pieces
13.51@104.27, but can run better as it is.
I just put a new 2100-2300 RPM TQ Converter. I hope a 13.20 or better
RAPTOR, the baddest bird on the planet
AIM HIGH!
Old Nov 21, 2000 | 03:27 PM
Larrys T/A's Avatar
Yeh i know the MPH is off. I still need a custom chip. I also have a HD Flywheel that weights 20LBS heavier than stock.
Old Nov 21, 2000 | 11:10 PM
BadSS's Avatar
Hey F22,,
Why you think you're over 5 mph off ONEORMULAOVERALL's speed? He doesn't even have a "big ole" cam. 109.75 mph? He11,, I'm barely doing that with heads and a cam!! I gotta get another exhaust,, or something!!!
[This message has been edited by BadSS (edited November 22, 2000).]
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
squiggy2
Aug 9, 2015 09:30 PM
Kaweh
Aug 9, 2015 02:54 PM
