cleaning intake carbon?
Old Dec 6, 2000 | 03:16 PM
Pino91Formula's Avatar
i was wonder what was the best method to clean the intake passages from built up carbon? as i think this is why im getting a code 32
thanks
Pino
91'Formula
LB9 305 TPI 5-speed
http://www.geocities.com/MotorCity/Garage/5654/mur91.jpg
Old Dec 6, 2000 | 05:57 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
I've always had good results with plain old carb cleaner. Cuts just about anything, including grease and carbon. Love that smell, too. If this is on a removable component, such as the intake plenum, I try to spray it well with the solvent then follow it up with a garden hose to flush out the loosened gunk. If you do this, just be sure to dry it well before re-assembling things.
Old Dec 7, 2000 | 02:01 PM
bjsiroc's Avatar
I used Gumout cleaner, it comes in a pressurized can and all you need to do is to pull off everything till you get to the throttle body then start the car and get someone to work the gas petal a little bit while you spray it in there. i know it sounds like it dosent work but believe me it will ive done it on mine 2 times and it says to do this every 12,000 miles. i think your code 32 is your egr valve too. its a pain in the A$$. done it all. give it a try you will be happy
Old Dec 7, 2000 | 02:59 PM
Yeah the 32 code is driving me crazy , ill try the gumout cleaner,
Old Dec 7, 2000 | 03:18 PM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Best stuff to use is GM Top Engine Cleaner.
This stuff is awesome. IF you are fuel injected, have someone work the gas pedal, and stick the brake booster hose in the can and suck it in. When it empties the can, the vacuum leak will kill the car like it is suppose too....
This stuff is awesome...
Sportsman II 72 CC heads, Pete Jackson gear drive, Performance Resources chip, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go stage 3 shift kit, Vigilante 9.5" 2800 stall convertor, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
raven.com
Old Dec 7, 2000 | 03:26 PM
it plugs into the vacume hose from the brake booster , and is sucks it through the plenum?
Old Dec 7, 2000 | 03:39 PM
raven350's Avatar
Engine: 5.7L
It is a can that has the old flip top style top. Where you bend back the ring and pull up on it(sort of like the old beer cans)
You take the hose off of the brake booster itself and stick it down into the bottom of the can. Trust me, it will suck that fluid out of the can. Once all the fluid is gone, the vacuum leak from the hose should be enough to kill the engine. Let it sit for fifteen minutes, and restart the car after you clean off the vacuum hose and reinstall it back on the brake booster.
The car will smoke out of the tail pipes pretty good(can we say smoke screen??) this is all of the carbon that the cleaner cleaned off.(make sure no small children or stupid friends are standing by the back of the car)
Old Dec 7, 2000 | 03:47 PM
where can i get this product? , now do you put the hose in the can and then startt it?
Old Dec 7, 2000 | 03:58 PM
Blade's Avatar
This product can be bought, like its name implies, from GM! LOL
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 12.9@107 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Old Dec 7, 2000 | 09:56 PM
raven350's Avatar
Engine: 5.7L
You can get it at any GM dealership. Just go up to the parts counter and ask for it.
And yes, stick the vacuum line into the can BEFORE you start the motor...
Old Dec 8, 2000 | 10:01 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
I wouldn't use carb cleaner unless you want to replace your 02 sensor sometime soon. That's why they have a f.i. specific cleaner. It PROBABLY won't hurt anything, but for 30cents extra why take the chance?
Maybe I'm missing something since I haven't seen the engine in my IROC for a few months, but I don't see how spraying cleaner into the brake booster line is going to help anything. The idle problem comes from funk clogging the IAC passages of the throttle body. To clean that you need to pull the IAC motor and hose it out up inside there and from the inlet of the TB. How is putting in cleaner from the booster line going to go upstream against the vacuum and clean the tb?
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
Old Dec 9, 2000 | 10:40 AM
raven350's Avatar
Engine: 5.7L
Original post is how to clean the intake passages....
The GM top engine cleaner works...
If you really wanted too.... You could also run a vacuum line in front of the throttle body into the intake and let the engine pull it in from in front of the plenuem, that is if you are worried about not geting the front cylinder ports of the runners....
Just letting you know what has worked for me before...
And the best way to clean the throttle body is to take it off. Couple of hoses, cables, and four bolts... 5 - 10 minutes top to take it off...
[This message has been edited by raven350 (edited December 09, 2000).]
Ducati900ss
Sep 2, 2015 09:05 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
