Can I put a cam in my 91z with the stock heads?
Old Apr 24, 2001 | 09:55 AM
m23haz's Avatar
Car: 91 Camaro Z28
Engine: 5.7 TPI
My mechanic is telling me that I cannot put a cam in (looking at the Crane 214/220) without taking the heads off. He says that the heads wont handle a cam with a lift over .450 so you have to modify them. Is this true? Can I put a cam in without taking the heads off?
1991 Z28 5.7L, Edelbrock headers, SLP cat back exhaust, Eldebrock intake base, SLP runners, GMPP 1.6 roller rockers, Hypertech Theromaster chip w/ 160stat, Accel 300+ race wires w/sleeve, MSD coil, relocated MAT, TB bypass, K&N's in gutted airbox
Old Apr 24, 2001 | 12:18 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
You can install a cam without pulling the heads off. I did, and the cam has .520 lift. Just make sure that you get the matching valve springs for the cam to prevent coil bind. Might as well replace the valve seals and timing gears/chain while you're at it.
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, Borla Cat Back, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Apr 24, 2001 | 12:46 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
He's right, the stock springs on the heads wont handle a lift over .450" or .460" lift. Get new springs with that cam that will handle the lift and you'll be fine.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Apr 24, 2001 | 01:56 PM
m23haz's Avatar
Car: 91 Camaro Z28
Engine: 5.7 TPI
I had new springs (off an LT1) and valve seals about 6k miles ago. I know that the stock springs wont hold the cam but he is saying that valves or something wont also. Bottom line is he said that the heads have to come off. I disagree with him but he wont listen. He says that he knows for a fact.
Old Apr 24, 2001 | 03:01 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
A camshaft can definately be installed without the heads being removed. What the hell kind of mechanic are you talking to????? If I were you I'd be looking for a new one..... The only thing you need to check is to make sure the valve springs won't be a problem, like others have stated. As far as I know, virtually all small block chevrolet engines will accept up to .490 lift. This could be different on a TPI engine, but I doubt it. The manufacturer of the camshaft you choose will recommend valve springs for that cam. I recommend using whatever springs they recommend - they tend to know what they are talking about.
Laterzzzzzzzzzzzzzzzzzzzzzzzzz
Matt
1987 GTA L98 MD8 GW6
"Stop Lights timed for 35Mph are also timed for 70Mph"
Old Apr 25, 2001 | 09:47 AM
Beefy89's Avatar
I'd get a new mechanic.
Fast as a shark~~~~~~~~~~~~~~~~~ SAVE NAPSTER!!!
Old Apr 26, 2001 | 08:48 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Even putting new springs in won't help the problem because the retainers are going to smash into the valve guides. Remove the heads and have the guides cut down.
Then put the new springs and cam in and enjoy!
Old Apr 26, 2001 | 12:56 PM
m23haz's Avatar
Car: 91 Camaro Z28
Engine: 5.7 TPI
Joel is right! Thats what my guy was telling me. BTW he is not some backwoods mecanic, he owns Mazzoni Racing in Vineland NJ. So you do have to remove the heads right?
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
TreDeClaw
Aug 14, 2015 06:58 PM
anesthes
Aug 8, 2015 09:37 PM
