Purchasing new injectors! which set to chose????
Old Jan 8, 2008 | 12:15 AM
The_Phoenix's Avatar
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Hey whats up? I have an '89 GTA with some mild mods (flowmaster exhaust, crane cam, rockers, chip and headers) and im facing a problem with leaky inectors; I guess that explains the noticable smell of gas in the interior as well as in the exterior when the hood is open! Im looking to purchase a new set and if you've read some of my previous posts, I want only whats best for my car and while im at it, upgrading as well so please no flaming about me spending 'x' amount of $$$ on injectors; Im not trying to be mr. money here and I know how much im willing to spend (dont mean to sound like an a*** either) . Anyway I'd like your opinion on these injectors http://www.jegs.com/webapp/wcs/store...59823_-1_10299, Im going for the 24lb. injectors and Im also looking to purchase this adjustable FPR to go with it http://www.jegs.com/webapp/wcs/store...46177_-1_10323
Tell me what you think! Thanks! L8R!
Old Jan 8, 2008 | 07:22 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Purchasing new injectors! which set to chose????
Stay away from Venom injectors. They seem to be going the route of Accel. Some sets are fine, some sets are junk.
Go with Ford/Bosch injectors found at this site. www.fiveomotorsports.com
I don't have personal experience with that regulator but you can get cheaper ones that work the exact same. TPiS loves to jack their prices up.
Old Jan 8, 2008 | 10:27 AM
kanmudhog's Avatar
Car: 89 formula ws6
Engine: yes
Transmission: yes
Axle/Gears: both
I just installed a BBK adjustable regulator , $70 for a blue aluminum shell with a bolt and a jamb nut , the bad thing was when I removed the old one I noticed the diaphram was starting to crack and split so I went to oriellys and got nailed for another $65 .
I would have saved money with the higher priced holley , it comes with a diapham and spring in the kit so everything gets replaced .
Old Jan 8, 2008 | 10:49 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Venoms no, Fords yes.
Old Jan 8, 2008 | 11:17 PM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Re: Purchasing new injectors! which set to choose????
Ok! so venoms are crossed off my list then lol! I'm still leaning towards the TPiS FPR due to the fact that it adds and extra 15 HP when tuned properly! That could change though since the holley FPR also caught my eye! As for the injectors, I would go with the ones off the five-o motorsports website but those are only 22lb. injectors and I'm looking to go with 24lb. like these ones that I found on the hawks website http://www.hawksthirdgenparts.com/in...OD&ProdID=2001 what do you guys think?
Thanks L8R!
Last edited by The_Phoenix; Jan 8, 2008 at 11:20 PM. Reason: Automerged Doublepost
Old Jan 9, 2008 | 06:16 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
When tuned properly. Gotta love it. To tune it properly and realize that "15 hp gain" you're going to need to scan, datalog, and then tune the ECM.
Don't expect 15hp from an afpr install without it.
Old Jan 10, 2008 | 01:04 AM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Damn! didn't know I had to do all that! I thought I just had to "tune" the regulator itself for the proper pressure level and voila! About how much would tuning run me? This also applies to all other adjustable regulators correct?
Thanks!
Old Jan 10, 2008 | 01:12 AM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
If I were you I would just buy a new set of Bosch injectors and not have to worry about them. If you buy a cheap set and they are garbage then you have to redo it all over again. I would just buy new from original maker and have no headaches.
Old Jan 10, 2008 | 03:17 AM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
I happen to run across these thru googling: http://www.racetronix.com/621022.html
Thanks!
Old Jan 10, 2008 | 03:43 AM
thegooseman's Avatar
Car: 1992 RS
Woa woa woa. Whats the matter with Accels? Thats what I have in my car. And when I say that I'm not defending them I just want to know if I screwed up by buying them.
Old Jan 10, 2008 | 04:47 AM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Well I've heard alot of complaints not just about Accel's fuel injectors but also about their coils, spark plugs, caps, etc. and have stayed away from that brand.
Last edited by The_Phoenix; Jan 10, 2008 at 07:09 AM. Reason: Automerged Doublepost
Old Jan 10, 2008 | 07:05 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I only ever had 1 problem with accels. I had 1 housing start leaking on me. A lot of people on HERE are having issues with them. The one set that I am still using is going on 5 years with no problems. Hit or miss apparently.
https://www.thirdgen.org/forums/diy-prom/
The stickies will answer most of your getting started questions.
Old Jan 12, 2008 | 10:39 AM
DAVEY420's Avatar
Car: 85 IROC Z
Transmission: TCI TH350 TCI 2400 STALL
Axle/Gears: 3.42 WORN OUT POSI
Yeah stay away from the Venom's, I got them with my motor swap and right out of the box I had a leaker. So I got another set and the car never ran right until I swapped them for Accel's. No problems since. I wanted the ford ones and they were apparently on backorder. I checked a few speed shops and no one could get them.
Old Jan 13, 2008 | 10:21 AM
the blur's Avatar
Accel has new and IMPROVED injectors.
it's a replacement line for the lousy ones, which are no longer on the market.
Old Jan 14, 2008 | 12:18 AM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Really? who carries them? and are you using them right now? I'd still like your guys' opinion on these: http://www.racetronix.com/621022.html
Thanks,
Ruben
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
hectre13
Aug 26, 2015 08:17 AM
Firechicken86
Aug 12, 2015 10:07 PM
