Is this crimp/restriction in '89 TPI fuel rail factory?
Old 02-19-2008, 12:47 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Is this crimp/restriction on a 1989 L98 350 TPI fuel rail factory? Originally I thought somebody slipped with a wrench and crushed it but once I got the fuel rail removed I noticed its also compressed from the underside. It looks like it was done with a pliers. I can't imagine somebody purposely doing this ??
Attached Thumbnails Is this crimp/restriction in '89 TPI fuel rail factory?-89rail1.jpg
Old 02-19-2008, 01:06 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Re: Is this crimp/restriction in '89 TPI fuel rail factory?
its not stock someone has crimped it / damaged it.
Mine is round and nice
that will restrict the flow of the fuel, fix it or replace it..
Old 02-19-2008, 03:04 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
most likely youll have to replace it.
Old 02-19-2008, 06:51 PM
Dens71TA's Avatar
I repaired it it this afternoon. I put a two-peice 3/8" ID diameter shaft collar around the tube and tighten it down. It reformed the tube back to round again. I'm surprised how well it worked!
Old 02-19-2008, 07:37 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
holy crap!I don't why anyone would that!
Inexpierience Is my only guess.Good job as far as reshaping it.
Old 02-20-2008, 02:59 AM
Theking's Avatar
Car: 1989 IROC-Z
Let us see a picture of the repaired object
Good work !!
Old 02-20-2008, 04:24 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
If that was the return side someone might have been trying to raise the fuel pressure.
What do you think?
Old 02-20-2008, 10:25 AM
Theking's Avatar
Car: 1989 IROC-Z
What do you think?
That one on the top is fuel INLET, the lower one is return
So it was the inlet that was "broken"..
crimping the inlet will raise the pressure to a little bit,
but this is NOT the way to do it..
Old 02-20-2008, 11:19 AM
chevhedz28's Avatar
Car: '89 formula,'88 Iroc
Engine: 350,305
sounds like some of that hillrod stuff to me. People who don't know this stuff shouldn't mess with it!!!!! It's makes me wanna smack the sh*t outta them!!!!
Andrew6.688
12-13-2015 10:59 AM
Brcharrelson
08-26-2015 07:47 PM
Sanjay
08-12-2015 03:41 PM
Armored91Camaro
08-12-2015 09:41 AM
92projectcamaro
08-06-2015 01:20 PM
Quick Reply: Is this crimp/restriction in '89 TPI fuel rail factory?
