Sick TPI.
Old Apr 28, 2008 | 08:53 PM
jcp74's Avatar
Sick TPI.
Hey guys, I'm having a problem with my 89 GTA with a 5.7 . When I crank it, it doesn't start, but, when I spray starting fluid into the throttle body it starts and runs fine? We put an injector test light onto the injector plug and it has a weak pulse. I tested the injectors with an ohmmeter and most are bad. our theory is that the bad injectors are robbing power and thats why were getting a weak pulse at the #1 injector. I need to know what the injector ohms need to be at. I've read many post, some say 14 ohms, some say 16 ohms, others say between 13 & 16? My mechanic is convinced that they need to be at 16 ohms and after market injectors wont work. but injectors from GM are $150 a piece any help would be greatly appreciated.
Thank you Jason.
Old Apr 30, 2008 | 08:26 PM
BlueByU's Avatar
Car: 1991 Z28
Re: Sick TPI.
Ford Motorsports injectors are probably the most popular replacement injector for TPI cars. I used 24# SVO Ford injectors and haven't had a problem with them.
I think if you search for "svo" "ford" "injectors" or something like that you'll find a lot of info.
Old Apr 30, 2008 | 09:19 PM
zj8urimport's Avatar
On Probation
Car: 89 Formula
Axle/Gears: 9 bolt 3.27
Re: Sick TPI.
Check you coolant temp sensor fuse, that's what did it for me.
Old Apr 30, 2008 | 11:12 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: Sick TPI.
i have a extra set of svo 24's never used 150.00 buys them
Old May 1, 2008 | 11:48 AM
jcp74's Avatar
Re: Sick TPI.
Thanks for the info guys, Crock I'll send ya a P/M.
Old May 1, 2008 | 02:40 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Sick TPI.
You tested the injectors with them unplugged from the harness, right?
Old May 1, 2008 | 03:08 PM
jcp74's Avatar
Re: Sick TPI.
Yes,
I unplugged the injector and and tested the injector itself.
Old May 2, 2008 | 08:29 PM
billybird's Avatar
Car: 89 Formula
Engine: LB9 TPI
Axle/Gears: 3.73(coming soon)
Re: Sick TPI.
i hope with a 9 volt batt.....
sheachopper
Jul 31, 2019 11:27 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Bradsaundry
Oct 7, 2015 04:35 PM
Linson
Oct 1, 2015 09:50 PM
earlpote
Sep 12, 2015 11:55 AM
