Distributor Issues?
Old May 23, 2008 | 04:45 PM
pa_richardson's Avatar
Distributor Issues?
What have i done?
I have just changed the distributor the whole thing i was carefull to mark were the rotor was pointing then placed the new one with rotor pointing the same way but he engine wont even try to fire it has a spark.
I tried pulling the post out and placing it a notch out then it tried to fire but with all my trying and moving i have now lost its positon completly i need to know how to set up the distributor point corectly from scratch and how to set timing correctly.
The fly wheel has a mark on it if that lines up with the markers is that top dead centre on cylinder one?
I am no proffesional at this please can somebody explain it in easy terms..I have a timing light but not even sure how to use that...please help its been 9 months now with no engine running after changing every electronic part except the distributor and pick up coil i then found the pick up coil was broken hence his problem..
Thanks guys
Old May 24, 2008 | 05:07 PM
Re: Distributor Issues?
Okay i have spent the whole day trying oget this engine started..
Please help me....PLEASE...
I took plug one out felt for tdc ish then checked rotor position it was pointing roughly to lead one on the cap.
I have tryed turning it left and right with tan/black disconnected but theengine will not start but very badly backfires..and floods itself..
I have spark and cleaned plugs...any ideas please..
Old May 24, 2008 | 09:14 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
There are 2 TDC on account of it being a 4 stroke engine.
Need TDC on Compression stroke ; finger over #1 plug hole while someone cranks engine, will blow finger off hole on comp stroke.
Old May 25, 2008 | 04:02 PM
Hi thanks for your help yes i can find when the piston 1 is at the top and have lined this with the rotor pointing to lead and plug number one.
You would think that thiswould be fine and the engine will start especially as it did start before i changed distributor.
I realise once it starts i need to fine tune it with the timing light but thats not good right now untill it does start..
Now i realise if the distributor is in the block slightly to the left or right than before simply turning the cap after should fix that..
But what about te pick up coil? Say i do aline the rotor correctly with TDC number 1 that does notmeen the pick up coil is now sending its signal at the correct time????Or does the ecm fix this?
You see if i try and start it now there is no life in engine if i rotate the dizzy it just starts backfiring on me...Then if i remove the dizzy and place it backin the block say one cog to the left it then may try to fire better???
I did cut the tan/black wire when turning dizzy??
Im out of my depth here wish i lived in the states there seems to be nobody over here in england that can help..
Old May 25, 2008 | 06:17 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
"i rotate the dizzy it just starts backfiring on me.."
That shows you have spark , so everything is working correctly.
It is just in the wrong place.
Are you sure your are TDC on compression stroke ; not 180 degrees out ?
Old May 25, 2008 | 06:31 PM
I have rotated crackshaft untill i feel the number 1 cylinder come up which i have done slowly and used screwdriver to feel with...this is when i lined it up with lead and plug number 1...Does this sound correct or would the cylinder come up also at a different stage of the firing?
Old May 25, 2008 | 09:29 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Can you feel the cyl pressure building when on this stroke?
Old May 25, 2008 | 10:38 PM
87SSTPI's Avatar
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
If worse come to worse, try moving ALL the plug wires one position back or forth on the cap instead of screwing with the dizzy. If you are close or even one tooth off, this should compensate for it. Heck, you might even have to move them two spots over.
Old May 26, 2008 | 12:48 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
The piston being at TDC doesn't mean you have it right.
There are two different times that the number one piston will be at TDC, the COMPRESSION stroke, and the EXHAUST stroke. If you put the distributor in and set it when number one is on its exhaust stroke, you just put your distributor 180 degrees out of time. Make certain it's on the compression stroke when you set the distributor.
Old May 26, 2008 | 06:20 AM
Hi yes that all maked sense i will run down to the garage today and have a go at that.
Thak you i will let you know how it goes..
Im also checking on the pickup coil as its new i readon here there may be 2 different ones both have different polaritys...something about one with a white wire one with a yellow...i need to look at old one to see what was on there before..when it was starting...
Thanks guys
Old May 26, 2008 | 09:18 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
My money's on 180 out. I've done that before and had the same issues as you.
Old May 26, 2008 | 04:41 PM
Yippppppeeee it runs thanks for all your help im notsure if it was 180 out i simply removed the dizzy pulled out plug one waited for it to come up to TDC looked at crankshaft marks lined them up with centre large cut out the put dizzy back in..First time it did not fire but then removing te dizzy cap i noticedthesmallcentre spring loaded pin was getting stuck in..
I changed that for the old one and bang it fired up great and runs great...
The dizzy got changed because i was having smoke problems from to much fuel this also was fixed and was the Pick up coil...
Thanks again
Paul
Frozer!!!
Jan 19, 2024 04:55 PM
777Shock777
Oct 29, 2015 04:30 PM
db057
Sep 4, 2015 07:57 AM
86IROC112
Aug 17, 2015 07:57 PM
stalkier
Aug 7, 2015 04:49 AM
