throttle body spacer?
Old Nov 20, 2001 | 11:12 PM
89tpi's Avatar
I just added the MSD coil and wires and now plan to move on to fase 2 of my upgrades air flow. I am going to get a K&N cold air kit from who i don't know. And was wondering since my car is pretty stock a 52mm is not worth it at this time but is a spacer worth it?
Old Nov 20, 2001 | 11:24 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I think spacers are good for TBI's and carb engines only
What would a spacer do on a TPI?
Old Nov 20, 2001 | 11:25 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Most likely would reduce his power band even more.
-- Joe
1989 Formula 350 4-bolt mains, Forged .030 TRW pistons, SLP 51010 Roller Cam, Comp-cams roller lifters, Summit 1.5 roller rockers, World Products Sportsman II
2.02/1.60 heads, Edelbrock TPI Intake, Cloyes Double Roller, timing chain, Mellings oil pump: 13.5 @ 100.23 MPH
Since close of track : Ported SLP runners, Ported Plenum, AFPR, Autometer 100lbs gauge, A/F ratio gauge.
http://www.joesperformance.com
-- Joe
Old Nov 21, 2001 | 03:02 AM
poncho9789's Avatar
If you have a tpi your runner leigenth is long enough I wouldn't put one on your car. You would be better served saving the money and spending it morewisely somewere else. Look into the tec-boards and find out what tpi mods are reccomended or do a search on the this board for the same subject.
Old Nov 21, 2001 | 09:07 AM
89tpi's Avatar
Sorry i ment to say airfoil.
Old Nov 21, 2001 | 09:59 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Save your money, man.
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Harland Sharp 1.5 rockers
Performer RPM Manifold
Holley 600 cfm double pumper
Hooker Super Competition Headers
Flowmaster Exhaust
Competition Engineering Sub-frame connectors
Tremec TKO
Pro 5.0 Shifter
GM posi 3.42 rear
Hurst Roll Control
13.9@102
http://www.geocities.com/thetpiguy/index.html
chemjoker@aol.com
Old Nov 21, 2001 | 10:32 AM
89tpi's Avatar
I looked in the tech area under suggested mods for TPI and the Airfoil is on there as one of the upgrades to do. However i hear mixed ideas when it comes to throttle on here.
89 Formula WS6 w/ TPI 350
MSD blaster coil and 8.5 mm MSD's
K&N filter
Old Nov 21, 2001 | 11:31 AM
nblanchard's Avatar
about the spacer idea... i was thinking of getting a product called airaid.. its a spacer with a helical bore in it, so it spins the air as it goes through and picks up more fuel onthe way into the cylinder. Depends if I go NOS or not... Which may be decided in the next week due to a 300dollar (candian) price on a NOS sytem
1988 Pontiac Trans Am GTA L98 5.7L, Black on Black with 114,000kms.
Best ET 14.559 @ 95.25MPH
Custom 3" Stainless Exhaust Y-Pipe back (High flow Cat and Flowmaster Mufler)
Old Nov 21, 2001 | 12:41 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Those spacers are a total waste of money for TPI engines as they don't affect the runner length, fuel atomization, or anything else besides giving you a lighter wallet.
Greg Westphal
'87 IROC 355TPI/A4
Old Nov 21, 2001 | 02:49 PM
Drakar's Avatar
TPI is a dry flow so unless you setup NOS at the throttle blades who cares if your air looks like a tornado, it will do nothing for you but as said above lighten the wallet, If you want I can take a drill and grind up your TB and you can give me the money instead.
Seriously, Airfoil is mixed results at best and a spacer is useless. save your money for some heads.
1989 Trans Am GTA, Gutted air box, K&N, Koni Sports
Old Nov 21, 2001 | 10:08 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I read an article in a hot rod type book
a while back about those little propeller
spacers.
They were popular in the 50s and 60s, and
were proven to do absolutely NOTHING
as well.
-- Joe
-- Joe
Old Nov 21, 2001 | 11:24 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
<font face="Verdana, Arial" size="2">Originally posted by 89tpi:
Sorry i ment to say airfoil.</font>
I doubt you'll gain any noticeable power by adding an airfoil. The only thing I noticed when I added mine was that my throttle response was slightly better... but that's it.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
