timing help
Old Jul 12, 2008 | 05:41 PM
88I_R_O_C_ZTPI's Avatar
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
timing help
i have read many articles on how to set the timing on a tpi car and every one i read is extremely confusing on 1 part because they never contain a picture of the timing marker and like most people i cant read the #'s on mine anymore .
so i am asking some one that knows 110% what the markings are to take my crude drawing i made of the marker and label it with the correct #'s where they belong so i am sure once and for all . thanks a bunch , and if a mod sees this please put the pic in the tech article on the home page on how to set the timing .
Old Jul 13, 2008 | 11:39 AM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
Re: timing help
guess the timing is wrong on every ones cars here ?
Old Jul 13, 2008 | 03:19 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: timing help
if i remember correctly 8*btdc was the mark at the end to the left, but ill see if i take a picture of mine
Old Jul 14, 2008 | 01:46 PM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
Re: timing help
nobody has a readable tab on their car ??
Old Jul 14, 2008 | 02:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: timing help
From left to right:
Edge 16 degrees BTDC
Point 12 degrees BTDC
Notch 10 degrees BTDC
Point 8 degrees BTDC
Notch 6 degrees BTDC
Point 4 degrees BTDC
Notch 0 degrees TDC
Point 4 degrees ATDC
Edge 6 degrees ATDC
Old Jul 14, 2008 | 02:05 PM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
Re: timing help
your my new best friend THANKS ! .
Old Jul 14, 2008 | 02:27 PM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
Re: timing help
so this should be right ,
Old Jul 14, 2008 | 02:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: timing help
Looks ok.
A dial-back timing light is a good investment so you don't need to worry about which mark is which anymore.
Old Jul 14, 2008 | 02:40 PM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
Re: timing help
ill put that on my 3 mile long toy list lol . thanks again ..
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
