An honest 300+ HP Crank.
Old Mar 30, 2010 | 11:49 PM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
I'm about to start building a L98. I have mostly stock parts, and I want the vehicle to maintain a stock look. What would be the best place to start looking for power? All I'd like is 300hp, maybe a little more, if i want to be greedy. Any suggestions?
Old Mar 31, 2010 | 09:50 AM
danziger's Avatar
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
Re: An honest 300+ HP Crank.
It seems the cam and intake base would be some good areas to improve. I will be watching this thread as I am going to be building a similar engine next year. However, I'd like to go with aluminum heads for the reduced weight.
You could also go with a 383, which would look stock externally. I've built a mild TPI 383 before and it was a blast on the street...
Old Mar 31, 2010 | 11:48 AM
actarnoff's Avatar
Engine: 355 TPI
Well, one of my options is rebuilding the motor with a LT4 hotcam, and port and polishing the stock intake and plenum, and maybe installing some shorty headers and a nice exhaust and a good tune.
Old Mar 31, 2010 | 09:25 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
with the LT4 cam.do you have to replace valve springs?....sorry to barge in on your post
Old Apr 1, 2010 | 12:12 AM
actarnoff's Avatar
Engine: 355 TPI
I think you do.
Old Apr 1, 2010 | 05:55 AM
danziger's Avatar
That should get you pretty close. My 90K mi L98 with just exhaust makes 220rwhp, so I'm think a fresh 355 with LT4 cam and everything ported would probably hit ~250rwhp or so...
Old Apr 1, 2010 | 11:27 AM
F-Body Demon's Avatar
My L98 is making 272 hp with a stock cam and stock manifolds and stock cats. I just ported the intake, tuned it and added ZZ4 heads (which do not flow very much more than stock heads).
So with that experience:
Long Tubes x-pipe and duals
Tune
Ported Intake or new runners
1.6 rockers (to crutch your cam)
AFPR
Should bring you close.
Old Apr 1, 2010 | 11:31 AM
Stephen's Avatar
Car: 87 GTA
Tune
AFPR
272 at the crank? Or at the rear wheels?
Old Apr 1, 2010 | 12:04 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Mine ran 234 at the wheels with headers and full exhaust. The hotcam is old, but it's still a nice cam. Won't get you all the hidden power that the new grinds can with their improved ramps, but I've known several satisfied Hotcam owners. You'll wanna switch to a double roller chain, and do some port work to the tpi. Maybe larger runners to match the porting of the intake and plenum. And as far as heads go, I would save money and buy some decent aft mkt heads rather than working the stock heads. The engine could still look very stock with a set of alum heads, once all the emissions lines and coolant hoses are in place you prolly wont be able to see them anyway!
Old Apr 1, 2010 | 02:53 PM
LS7Roc's Avatar
Car: 88Roc Flame Red Black/Gold Pkg
234 at the wheels with just headers and exhaust...not bad.
Old Apr 1, 2010 | 03:45 PM
norcalz28's Avatar
Myself and another L98 owner here both picked up about 20rwhp when we went with hedman 1-5/8" shorties with y-pipe
Old Apr 1, 2010 | 04:44 PM
Abubaca's Avatar
Tune
AFPR
GOTTA be crank. ...even then I gotta wonder. LOVE to see it be true, but that's pretty insane
Old Apr 1, 2010 | 05:32 PM
272 Crank according to an iPhone. ABUBACA U should come check it out if your not a believer haha, seems like there are no thirdgens out here in eastern NC
Old Apr 1, 2010 | 05:56 PM
Stephen's Avatar
Car: 87 GTA
272 Crank according to an iPhone. ......
How in the world can an iPhone hook up to engine & measure horsepower at the crank?
That was a rhetorical question, because I already know the answer...NOT POSSIBLE!
Lemme guess....Your basing that on some kinda simulation software, like Desktop Dyno? Or some kind of GPS phone-based software(which would be rear wheel hp)?
Old Apr 1, 2010 | 09:06 PM
Its the exact same concept as a G-TECH, it uses the accelerometers in the phone and measures the 1/4 mile. Its pretty accurate actually, at least thats what hotrod magazine said about G-TECH and the whole accelerometer thing.
It called my stock GTI 197 hp when its advertised at 200.
But maybe you still dont believe me, maybe you will believe the guys at autoblog http://www.autoblog.com/2008/07/29/d...ormance-meter/
Or Road and Track http://www.bunsentech.com/2009/dynol...oad-and-track/
RS Reaper
Oct 17, 2018 07:52 PM
MM2Robinson
Oct 1, 2017 09:16 AM
Linson
Oct 1, 2015 09:50 PM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
