305 missing and dies at idle.
Old Apr 13, 2010 | 06:56 PM
massaku's Avatar
Car: 84 15th anniversary Trans Am
Engine: 305 H.O. L69
Hey guys I finally got my car to start after replacing the whole entire ignition system and adjusting the timing but now that its running it runs like complete crap. It sounds like it is only running off a couple of cylinders. I can start the car by flooring the pedal but once it is running it dies right away unless I warm it up then it will idle at 1k rpm. It is not throwing an engine light or anything so what could it be?
Old Apr 14, 2010 | 05:03 PM
massaku's Avatar
Re: 305 missing and dies at idle.
New development.
I tested all the cylinders and the whole passenger side of the engine
is dead... I checked the spark wires and I am getting voltage so it has to
be something with the injectors right? I do find it weird however that one
side of the engine is dead and the other isnt... electrical problem maybe?
Old Apr 15, 2010 | 12:28 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Originally Posted by massaku
New development.
Hello massaku!!
There are two fuses for the injectors, one for each bank, check them first!!
Old Apr 15, 2010 | 02:06 AM
massaku's Avatar
Originally Posted by 87IROC-DAN61
Hello massaku!!
....I think I took a fuse out thinking it was the fuel pump fuse...and I dont know if I put it back in...I will check in the morning...
Old Apr 15, 2010 | 02:31 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
I was going to suggest the fuse as well... otherwise if it's operational, then you will have to get your hands on a manual so you can diagnose that side of the harness with a 12 volt meter or a voltmeter to see how much juice is getting through ...
Old Apr 15, 2010 | 06:01 PM
massaku's Avatar
You guys were right... lol.
The car is running on all 8 now but still lacks alot of power and
hesitates when you give it gas. I did however get to take it on its
first cruise and it was great!. Although going up a hill it wont go past 2k rpm
in drive with the peddle to the metal.
Old Apr 15, 2010 | 07:47 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
could be your catalytic converter that is plugged ... when you set the timing did you prep the car to set the base timing?
Old Apr 16, 2010 | 02:03 AM
massaku's Avatar
Hmm I dont really know how to check if its plugged... care to enlighten me?
and I dont really know what you mean by prep but I brought the number one piston up and put the rotor in the number one position and went from there.
I used my dads 87 GTA as a base and got it to idle at about the same position.
**EDIT** I also broke this little vaccuum line and I dont know if it has a lot to do with it... The yellow arrow is where it starts and the red arrow is what I broke...
eightsixseven
Dec 16, 2024 01:50 PM
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Wade787b
Sep 29, 2015 01:15 PM
