48 or 52mm throttle body and 24lb injectors..
Old Jun 12, 2010 | 12:24 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
hey i was wondering which throttle body size would be better for a ported edelbrock/slp tpi (ported and welded by dr j performance) slp cold air intake gm hot cam and afr 195 on a fresh 355 block.. this combo should produce around 350 to the wheels and would 24lb injectors and a afpr be enough injector for 350 wheel power.... thanks in advance..
Old Jun 13, 2010 | 12:31 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: 48 or 52mm throttle body and 24lb injectors..
go with a 58mm throttle body and 24s should be good enough. btw what fuel pressure you running your car at.
Old Jun 13, 2010 | 12:48 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
A bigger TB on even a modded 350 TPI isn't necessary as a TPI, by design, is not for revs. A stock 48 w/a foil flows over 700 CFM which is plenty for a 5500 RPM engine. Now, an engine with a HSR, Mini Ram, etc. is a different animal. TPIS claims they can make 450 HP with 22 lb injectors, at an elevated pressure, so 24's should be plenty. Spend the $300 from the TB on a razor sharp tune. That'll make the biggest difference.
Old Jun 13, 2010 | 01:32 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
well in my own personal expereince i had best results with a 58
Old Jun 13, 2010 | 09:12 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
58mm tb is way over kill. Run a 52 mm tb at most. I run a 52 with great results
Old Jun 13, 2010 | 08:24 PM
88fastgta's Avatar
well my throttle body is over 20 years old and im sure it needs to be serviced..... how do i serivce it to make it like new again....... but i really want a new 52mm throttle body...
Old Jun 14, 2010 | 02:09 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
go to autozone or pepboys and they sell a rebuild kit. its simple just a few gaskets and orings. make sure you also get a bottle of carb cleaner. i like brake cleaner best even though it aparently breaks down rubber it cleans parts so much better
Old Jun 14, 2010 | 03:56 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Check the throttle shaft to throttle body bushings for wear and slop. excessive wear will be an vacuum leak past the bushing and will make the butterflies stick in the holes.
There are guys that can repair this area but the cost is about that of the upgrade.
on the auction site:
extreme-fi sells remanufactured TPI TB bored to 52 mm for $150.00 or 54 mm for $180.00.
CNC motor sports has some billet TPI TB 52/56 mm for $175.00
I have no experience with these.
Old Jul 28, 2010 | 04:22 AM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Just a note, I had inconsistent idle with my 25yr old 48mm TB, so I put a new BBK 52mm on and the idle is smooth and steady now. I just bolted it on and set the TPS to .54 volts. It was well worth the $309 from Summit. Its been years since the Z28 had a good idle. I always thought it was something else and replaced a bunch of other parts. The old TB was flat-*ss worn out all this time...LOL
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
hydrolic144
Oct 4, 2015 08:23 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
