How far can i go with the stock prom?
Old Jul 5, 2010 | 09:35 PM
GtaCruizin's Avatar
i need some advice on this. i have a 91 gta. its a 305tpi 5-speed MAP sensed. i have deleted the smog pump completly, new belt and routing, blocked off egr, air foil, big cone filter, gonna be cutting off the cats, and got dual 3" out the back.
how far can i go untill the stock MAP prom needs to be reprogrammed? or would it be better to change the computer and put in a MAF set up? out of say an 88 formula. any advice or input is appreciated.
Old Jul 5, 2010 | 10:04 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
Re: How far can i go with the stock prom?
id stay map. and with those deletes you wont NEED to reprogram anything unless your going beyond basic deletes
Old Jul 5, 2010 | 10:20 PM
GtaCruizin's Avatar
what if i decide to go bigger either internal or a booster. reprogram MAP or convert to the MAF?
Old Jul 5, 2010 | 10:35 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by GtaCruizin
convert to the MAF?
Why do you think you have to go to MAF?
If anything MAF owners convert to MAP
Old Jul 5, 2010 | 10:47 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
And for people that get bored with that, they switch to LT1 with both MAP and MAF. lol.
Going bigger whether injectors or cylinder volume or anything of that nature will always be better suited with a tune. Where you're at right now is probably the limit, of which i've read many times that a MAF computer system is much more forgiving of upgrades than a MAP system is, but if you've gone that far so far and no issues, then cutting the cats and changing exhuast isn't going to hurt much more. Get where you're going, and plan your next step accordingly. If you don't wanna tool around with multiple tunes, plan your next step, if you wanna go 350, if you wanna cam, ect. Then get a tune and enjoy your progress.
Old Jul 5, 2010 | 11:02 PM
Stephen's Avatar
Car: 87 GTA
I'd ditch the cone filter & set up a CAI. Sucking in the hot underhood air isn't the way to make more horsepower.
Old Jul 5, 2010 | 11:36 PM
GtaCruizin's Avatar
i can get the MAF parts cheap. but say without my stock prom reprogramed and it still runs fine, i was wondering if the MAF will get more out of the mods? i dont want to do much with this engine i was looking into building twin turbo 350tpi. and buying the programing equipment then but maybe ill just jump into it now. any advice on info and or parts for programing?
Old Jul 5, 2010 | 11:45 PM
Stephen's Avatar
Car: 87 GTA
Learn to tune on your stock engine & not use a custom built twin turbo to start learning tuning on. Or maybe you already know how to tune, but I'd think you wouldn't be asking for info on tuning parts.
Old Jul 5, 2010 | 11:50 PM
84redta's Avatar
Yea, definately learn how to tune your stock engine, or turn around and have someone tune your new engine plans and learn from there with that base starting point. Just up and learning how to do tuning is not for something to learn over the weekend. I have a reprogramable pcm on my LT1 and that is still a guess and test method to find the best possible setup to maximize your setup.
Old Jul 6, 2010 | 09:51 AM
GtaCruizin's Avatar
ok thanks for the words of advice. i am very familiar with computers and very good with cars but ive never used them together, yet. i had some ideas what to get i just didnt want to spend like 800 bucks rite now. ill look around some more. thanks.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Genopsyde
Oct 7, 2015 08:35 PM
Keith5
Aug 27, 2015 04:37 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
