It always started fine... untill today.
Old Sep 3, 2010 | 08:31 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Ok guys, help me out.
I have a 1990 iroc 350 TPI. It has never given me any engine problems and has always run beautifully. Until today
I was in the middle of the street turning it around, and it just randomly died in the middle of the street. Had to have some people help push me into the garage. I just put about a quarter tank of gas in it so if that answers any low gas level on a hill questions.
It seems like its not getting any gas, but the PO said he had recently replaced the fuel pump.
Any ideas?
thanks
Old Sep 3, 2010 | 09:11 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
Re: It always started fine... untill today.
First I would check to see if your getting spark, it sounds like your ignition module died.
Old Sep 3, 2010 | 10:02 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Thanks for the advice, but I went out and got dinner, came back and started it, fired right up! Any ideas what it would have been?
Old Sep 5, 2010 | 05:43 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Well thats kind of what they do they stop working when theyre hot and then an hour later it will fire up. If it happens again just know that its the module.
Old Sep 5, 2010 | 11:02 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Ok so today it wouldn't fire at all. Where is the module located? How much would a new one cost?
thanks
Old Sep 5, 2010 | 11:08 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
under the dist. cap,you need a 5.5mm 1/4 drive socket on a nutdriver or ratchet.
they are normaly $ 20-30.
Old Sep 5, 2010 | 11:10 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Ok thanks alot
Old Sep 5, 2010 | 11:17 PM
regal301's Avatar
Car: 1988 iroc-z
http://www.megamanual.com/ms2/GM_7pinHEI.htm
yours will be the bottom left.
get the cap and rotor off and you will see it.
coat the bottom with the silicone grease they give you before you put it in.
Old Sep 5, 2010 | 11:22 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Thanks regal. I will let you know if I have any more problems.
Old Sep 11, 2010 | 03:16 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Ok, so I got the new module installed, went to start it, and still wont fire!
Any more ideas?
Old Sep 11, 2010 | 03:37 PM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
im betting fuel pump...
have you checked all fuses?
do you hear the pump prime when you turn the key?
Old Sep 11, 2010 | 04:06 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
I can smell gas when its turning over though. And I checked most of the fuses, which one would this problem be from?
Old Sep 11, 2010 | 05:16 PM
regal301's Avatar
Car: 1988 iroc-z
you need to find out what your missing,fuel or spark.
it takes fuel,spark and compression to run a motor.
i doubt it lost compression.try a shot of starting fluid so you can eliminate the fuel system.then post some results.
Old Sep 11, 2010 | 08:12 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Would the distributer be a cause? when I took off the cap the contacts were dirty and the rotor was as well. Could I need a new distributer?
Also which fuse would be responsible for this, if any
Orr89RocZ
Apr 25, 2016 08:28 AM
apo_bailon15
Mar 28, 2016 05:20 AM
TheExaminer
Aug 26, 2015 04:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
