The official First fuel injection tpi system build (100 percent installed and video )
Old Jul 8, 2011 | 08:25 PM
  #151
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Re: The official First fuel injection tpi system build
Originally Posted by 88fastgta
and here is a better pic of my fuel regulator location.... you see i can use the factory return line hose that will screw into the bottom of the regulator... all i need is a adapter to connect the hose to the regulator... all thats required now is two new lines which i will post pics eventually...
Also what kind of upper strut mounts are those????
Old Jul 8, 2011 | 08:26 PM
  #152
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
sure i will get close up pics of the coil tomorrow.... its dark out here in north carolina already.....
Old Jul 8, 2011 | 08:31 PM
  #153
88fastgta's Avatar
im using umi adjustable strut mounts... it allows better caster and camber adjustments that are not possible with stock strut mounts... these also use chrome moly teflon spherical bearings instead of the stock rubber ones and they provide extra travel for lowered cars which my car is lowered....highly suggest getting these if your serious about handling.... here is the link to the caster plates
http://www.umiperformance.com/catalo...roducts_id=402
Old Jul 8, 2011 | 09:56 PM
  #154
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Oh yes am serious about handling..Have a ton in the suspension already..Just put new mounts on mine, but would love the extra camber....Those look tight also...My 89 is a real canyon carver as it is, blows my 92 Z28 away..Of course it is about 500 pounds lighter too which helps a bunch..Thanks for the reply..I look forward to reading more on your install......Good luck...
Old Jul 8, 2011 | 10:11 PM
  #155
88fastgta's Avatar
i have tons of suspension mods myself.... its pretty much full bolt on from front to back...i would put that summit card on those umi plates and use it to beef up that 89... they are worth it
350tpi's are nice but they need alot of work to get decent numbers out of them.. i would rather have a cornering freak than a all out powerhouse for the street......
http://www.summitracing.com/parts/UPI-2040-B/
Old Jul 8, 2011 | 10:37 PM
  #156
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Thats about all i dont have on it have umi control arms, and panhard hothkis subframe connects, all energy suspension pieces, even a arm bushings..Am going to look into those, they really look neat..i have a, lot more invested in the drive train, than the motor, or i should say the underneath of the car..It launches way better than the 92, out handles it too..of course past 100 foot the 92 has its way with its weaker brother......i kinda like having both the 89 runs 14's the 92 13's, so they are both fun to drive...the 02 Z has energy suspetion parts, but thats about it....500 pound difference in weight too tho like i said.Thanks..Tom
keep us posted.......
Old Jul 9, 2011 | 06:12 PM
  #157
88fastgta's Avatar
well guys im goin to start now.... so ill be back tonight with pictures of the teardown.......
Old Jul 9, 2011 | 08:50 PM
  #158
88fastgta's Avatar
ok guys i started tearing down the old tpi... i just got off work so i only spent about an hour and im already down to just the base and dizzy.... i will mark the dizzy positions on the firewall so i wont have to take the spark plug out and find top dead center and all.. marking makes it close and will start right up without much issues... i will still need to use a timing light just to make sure but it saves alot of time..... just trying to get a early start.... will start back sunday morining....
Old Jul 9, 2011 | 08:54 PM
  #159
88fastgta's Avatar
i already started putting on the custom fuel lines and the vacuum line to the new regulator.... looks nice and neat and sorta looks factory...
Old Jul 9, 2011 | 08:55 PM
  #160
88fastgta's Avatar
and the two plenums side by side..... i dont have a picture showing this but the ports are MUCH bigger on the first and the plenum is bigger than the stock plenum....
Old Jul 10, 2011 | 08:16 AM
  #161
88fastgta's Avatar
ok guys everything is off... goin to put the base on in a couple hours... need to clean up the ports and everything...
Old Jul 10, 2011 | 08:29 AM
  #162
gbayfisher's Avatar
Car: 1987 Trans am GTA
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Nice and clean.
Good progress!
I see you have your oil sender in place
Once you put the base on, check our port alignment if you can to see if they line up. Mine had to be milled to get the perfect line up. That is with milled heads and block.
Old Jul 10, 2011 | 09:47 AM
  #163
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Hope we get some before, and after 1/4 miles times, and mileage.....................
Old Jul 10, 2011 | 01:27 PM
  #164
88fastgta's Avatar
well ran into two problems...
1... the oil sending unit adapter is too wide so i had to get a much smaller one to fit.... got that resolved..
2... the intake bolt holes dont quite line up to the head.... so i have to enlarge all the holes one size up on the intake manifold for it to work......
i have to go to work so i will resume either later today or early in the morning monday..
Old Jul 10, 2011 | 04:11 PM
  #165
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
by the way i ditched my so called "ls1" rear end... come to find out after further inspection it was a lt1 rear end and it had 3.42 gears instead of the 3.73 that the guy said it was.. so the guy screwed me out of 260 bux but im getting a refund and getting a real torsen ls1 rear wed the 13th from a auto salvage yard.... it has 55,000 miles, zexel torsen rear has 3.42 gears and theh ls1 brakes... so with the first intake and swapping out from 3.27 nine bolt to a 3.42 ls1 ten bolt all in the same month, i really should see a HUGE improvement for sure...
My bet is you'll be really happy with that 3.42 gear. Can't wait to see how it all turns out for you. Good Luck!
Old Jul 11, 2011 | 09:34 PM
  #166
88fastgta's Avatar
well i finally got the manifold on.... it was a major pita to install because the bolt holes were a little off and the oil sending unit adapter was hitting the back of the base.... so we had to enlarge every intake bolt hole a little bit and grind the 90 degree oil adapter... but after five hours of trail and error my dad and i finally got the intake on.... and its sealed good... we used plenty of rtv sealant across the back and front of the block and put a little bit of rtv around the water passages....
jlkjllj
Old Jul 11, 2011 | 09:36 PM
  #167
88fastgta's Avatar
shortly after i got the injectors and fuel rail on and the custom fuel lines are all on the engine.... (excuse the valve covers... new valve covers are coming shortly..)
nljkhljlkhjkl
Old Jul 11, 2011 | 09:39 PM
  #168
88fastgta's Avatar
i already have all the driver side runners on...... i will finish up the passenger side runners in the morning.... I will get more pictures tomorrow im about 80 percent complete here.... everything else is a cake walk now.... i will be done tomorrow... so i will be starting it up tomorrow evening....
Old Jul 12, 2011 | 07:34 AM
  #169
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
prepare to retune
Old Jul 12, 2011 | 07:46 AM
  #170
88fastgta's Avatar
thanks man..... yeah i will get it retuned pretty soon
Old Jul 12, 2011 | 07:48 AM
  #171
88fastgta's Avatar
well i got the runners and plenum on.. those were a cakewalk to do.... just need to put the dizzy in and a little things now.. should be all finished up in a few hours... this thing looks insane in the engine bay...... valve covers should be coming soon.....
Old Jul 12, 2011 | 12:15 PM
  #172
88fastgta's Avatar
INTAKE IS DONE....... 100 PERCENT COMPLETE.... combination of superrams peformance and top end with tpi low end grunt will make the first the best of both worlds......
Old Jul 12, 2011 | 12:22 PM
  #173
thegooseman's Avatar
Car: 1992 RS
Looks really good. Maybe I should ditch my miniram too for this piece.
Old Jul 12, 2011 | 12:25 PM
  #174
88fastgta's Avatar
if its strictly street use its hard to beat a first intake with supporting mods.... i havent started it yet... need to get coolant...
Old Jul 12, 2011 | 12:51 PM
  #175
GTA90X's Avatar
Car: 1990 GTA
Engine: stock L98(being pulled for rebuild)
Transmission: stock 700R4
I've been following this thread closely and want to say thanks for documenting everything in such detail. I plan on topping off my new 383 with a First sometime next spring and all your info has been extremely helpful.
Looks great and can't wait to hear how it all turns out.
Old Jul 12, 2011 | 01:19 PM
  #176
88fastgta's Avatar
thanks man...... i cant wait to start it up today.... i will let you guys know the difference....
Old Jul 12, 2011 | 02:32 PM
  #177
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
I wish this came in a Ca smog legal version
Old Jul 12, 2011 | 02:35 PM
  #178
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
hope you get a start up video....and i can't wait to see the results
Old Jul 12, 2011 | 06:22 PM
  #179
Car: 1992 RS
I thought there was a provision for the egr. If there is it would be pretty damn hard to tell the difference from a stock manifold to this if your a smog tech. Unless that tech knows a thing or two about thirdgens.
Old Jul 12, 2011 | 07:41 PM
  #180
88fastgta's Avatar
there is a port for an egr.... i didnt use it because im not running a egr..... i have a start up and idle video tomorrow as well as what improvements this has over my old tpi
Old Jul 13, 2011 | 10:47 AM
  #181
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Problem for using it in CA is aftermarket parts have to carry a CARB EO number, if it doesn't have that you can't use it. $1200+ bucks is kinda spendy for a manifold you "might" get away with using and if you do get busted I think there are fines involved.
Old Jul 13, 2011 | 10:48 AM
  #182
Re: The official First fuel injection tpi system build (100 percent installed)
Looking good man! is the TPS just a bolt on item? I noticed it wasn't on in any of the pics.
Old Jul 13, 2011 | 11:20 AM
  #183
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
yeah this is exactly why I have an accel base and runners for now. My old man is a smog tech and he knows his cars well he has called me out on a few items not having e.o numbers.
That intake is looking great on top of ur engine tho cant wait to see the video. Did you do any porting or siamesing
Old Jul 13, 2011 | 01:46 PM
  #184
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
i wish i had that kinda cash thats just what i need i want 2 keep the tpi look with about 350 no more than 500 to the fly im running a LB9 mild cam full exhst 9bolt 327
Old Jul 14, 2011 | 06:26 PM
  #185
TORN's Avatar
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
Update?
Old Jul 15, 2011 | 08:20 AM
  #186
Car: 91 Trans Am
Engine: 355 TPI
hes oviously out enjoying it!!!
Old Jul 15, 2011 | 01:23 PM
  #187
88fastgta's Avatar
sorry guys i took too long..... this thing has soooo much more low end and top end that its not even funny.. really pulls hard to about 5800rpms.. i will not fool with another gm tpi ever again after running the FIRST.. defintely runs like a raped ape...... i would highly suggest getting one of these....... ill have a video here shortly.....
Old Jul 15, 2011 | 01:24 PM
  #188
88fastgta's Avatar
sorry for the delay... yes there is a place for the tps switch... i just didnt bolt it on during any of the pics..... its in the same location where it at on the stock throttle body.....
Old Jul 15, 2011 | 01:32 PM
  #189
BLKIROCZ87's Avatar
Car: 87 Black Iroc-Z
Engine: 305-LG4/ Soon to be ?
Transmission: TH-350/ soon to be ?
Axle/Gears: 3.73 POSI - Auburn -
Wow congrats!!! you def feel a diff. huh.. Did you have to tune it if so was it difficult...?
Cant wait to see vid, def make one..
Old Jul 15, 2011 | 01:41 PM
  #190
88fastgta's Avatar
more like a huge difference.. all on the same tune i had with pcmforless with my old tpi.. im telling you you guys really need to grab on of these... there is no comparison between the two.. i would love to see a stockish ls1 and murder him...i feel that confident.
Old Jul 15, 2011 | 02:29 PM
  #191
Recaro trans am's Avatar
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
I need this!!!!! Has anyone used this with a blower set up? If so what kind of results?
Old Jul 15, 2011 | 03:43 PM
  #192
Engine: L03 305 TBI
Next project needs to be to let that puppy BREATHE!
http://www.gmhightechperformance.com...ipe/index.html
Old Jul 15, 2011 | 08:20 PM
  #193
88fastgta's Avatar
idle video with the FIRST TPI
http://www.youtube.com/watch?v=NZSIz_Fv7aw
Old Jul 15, 2011 | 08:37 PM
  #194
Engine: L03 305 TBI
Re: The official First fuel injection tpi system build (100 percent installed and vid
Man, I love the way that sounds. i never realized an LT4 HotCam had that much lope at idle.
How much vacuum do you have at idle?
Hmmmm ... a lot less lope here, and much quieter, yet the exhaust is listed as the same. What's different?
http://www.youtube.com/watch?v=Kij_l...eature=related
Old Jul 15, 2011 | 08:42 PM
  #195
88fastgta's Avatar
thanks man..... mods are in the "show more" section of the youtube page.... i love the way the hotcam sounds for my setup..... i dont want to change cams but i want to get rid of those garbage l98 iron heads for some afr heads now... i had the idle set at 850 from my old tune..... im not sure about the vacuum at idle but it i havent had problem with stalling out or anything.... now i know why its called the "FIRST" it comes in first place when it comes to tpi...... and people say you cant have tpi and a lumpy idle.....
Old Jul 15, 2011 | 08:46 PM
  #196
88fastgta's Avatar
http://www.youtube.com/watch?v=Kij_l...eature=related[/quote]
i used a different phone for that particular video... it sounds way muffled and bassy..... plus my chip was tuned for the old tpi... i guess with the added air and more power it changed the sound of the cam im not sure but it does sound lumpier for sure.... .
Old Jul 15, 2011 | 08:48 PM
  #197
Engine: L03 305 TBI
No, what I was saying was, in the older video of your car I posted, it was much quiter, and seemed to lope less. When I checked the mods you listed on both videos, both list the long tubes, 3", and Flowmaster 80. Was the older one before you hogged out the cat, maybe?
Old Jul 15, 2011 | 08:51 PM
  #198
Engine: L03 305 TBI
i used a different phone for that particular video... it sounds way muffled and bassy..... plus my chip was tuned for the old tpi... i guess with the added air and more power it changed the sound of the cam im not sure but it does sound lumpier for sure.... .[/QUOTE]
Lumpier is better!
And that Flowmaster 80 sure sounds a lot better than my Flowmaster 40. Do you end up getting any "special attention" from LE with that exhaust?
Old Jul 15, 2011 | 08:54 PM
  #199
88fastgta's Avatar
your right i havent changed the exhuast.... the only thing i have changed engine wise was the intake.... i used a video camera for the first tpi where i had used my camera video phone for all the others... the video camera sounds alot better than my cheap camera phone which doesnt pick up sound nearly as good. i didnt sound that lumpy with the old tpi im guessing because with my old system i had the chip tuned for that car.... but since i changed to the FIRST it idles meaner.... im guessing its because the new intake changed the air delievery and the computer trying to compensate for it.... either way im sure when i get a tune it will smoothen out abit.....
Old Jul 15, 2011 | 09:01 PM
  #200
88fastgta's Avatar
Lumpier is better!
And that Flowmaster 80 sure sounds a lot better than my Flowmaster 40. Do you end up getting any "special attention" from LE with that exhaust?[/quote]
to be exact my exhuast mods are
hedman long tube headers with custom 3 inch flanges with custom oxygen sensor bung into the driver side header
3 inch y pipe made at henry's muffler shop
gutted 3 inch catco converter
flowmasters 80 series
3.5 inch tips.....
its a new fresh block with a much better roatating assembly and slightly higher compression than stock..... the engine has alot of special work done to it... its .6 grams off from being perfectly balanced.. it has been blueprinted and the rings have been specially gapped for street strip use...... the heads have been rebuilt from the ground up using manely parts to handle the hotcams lift.... i did not use gm's spring kit for the hotcam because they barely pass for being able to withstand the hotcam so i used much beefier springs.....
