What is the drivers side small runner tube function? Tricky!
Old May 26, 2011 | 12:23 PM
385IN2005's Avatar
Car: '97 GTP
Engine: 385 sbc, 3.8 Supercharged L67 V6
If I'm deleting the cold start injector on an 88 and earlier TPI system, can I use the later 89-92 runners without the cold start privision and without the small tube?
Is that tube strictly to feed air to the cold start injector, or does it also play a role in the function of the IAC?
TPI setup will consist of:
-'87 plenum
-'87 base
-'87 throttle body
-'89-92 runners?
Thanks!
Old May 26, 2011 | 02:55 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: What is the drivers side small runner tube function? Tricky!
that is the egr crossover tube, it should be present on either type of runners.
Old May 26, 2011 | 03:11 PM
385IN2005's Avatar
Car: '97 GTP
Well, the stock '89 driver side runner doesn't have that tube at all and if you buy '89-92 slp runners, it is blocked off at both ends of the tube.
Old May 26, 2011 | 03:59 PM
Both of my 89 'birds and my 86 Z all had it, I never seen one that hasn't.
Old May 26, 2011 | 04:01 PM
Twin_Turbo's Avatar
The tube on the drivers side is for the cold start injector and as such, not present on 89? up. The passenger side EGR tube is there on all of them
Old May 26, 2011 | 04:16 PM
385IN2005's Avatar
Car: '97 GTP
So, the driver side tube isn't needed if you've deleted your cold start injector, right? I can use the 89-up slp runners with the older style plenum?
Old May 26, 2011 | 04:28 PM
385IN2005's Avatar
Car: '97 GTP
Here are two pictures of my 1989-92 TPI runners. No driver side tube.
Old May 26, 2011 | 07:38 PM
my bad, the egr tube is on the passenger side, it's been a few years since i've actually looked at one
Old May 26, 2011 | 08:37 PM
87TTops's Avatar
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
You can see where they delete the cold start tube. You're good to go.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
GVMV
Aug 16, 2015 07:08 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
